Expensive lesson
Old Aug 14, 2014 | 03:04 PM
bikerlaw's Avatar
bikerlaw
Originally Posted by fabrik8r
The NAPA in my town looked through all of their books and was not able to find a + size repair plug for the o-ring sealing plug like the one used on the Harley oil pan. If you have a part number that would be very helpful.
I do not. I have used them on only two different occasions, and if I had to guess, they were for automotive style oil pans. That being said, to my knowledge, both of the ones I have personally installed are still on the bikes and working perfectly. Remember fabrik8r, this is not a factory repair. This is nothing but a self tapping bolt for idiots like myself who strip the wafer thin MOCO oil pans, and don't want to install new ones. If your looking for a correct, o-ring self tapping drain plug, this isn't the answer. They are just a quick fix. But they work.
Old Aug 14, 2014 | 05:25 PM
KEYBEAR's Avatar
KEYBEAR
Took my 2013 Street Glide in for the 1,000 mile service . A week later I see a drip under the bike . I get a flash lite and sure enuff drain plug stripped . Call the dealer and of course no way his service guy did that ( who did ) . Well they put a new pan on it at no cost .
Old Aug 15, 2014 | 05:43 PM
UltraZac's Avatar
UltraZac
If it wasn't for the fact that I was going to leave on a long trip the next morning, this whole thing may have not happened. I did have the plug turned in about 3 or 4 turns before I put the socket to it. Turns out the threads on the plug were cut very shallow (check your plug threads). The mechanic installed a helicoil insert and better plug. So the final bill was 1.5 hours labor at $100 an hour. On the receipt it says flushed with Syn3, so there's another $60. After taxes and a new plug, $250. From now on whenever I change my oil I will be turning the plug in as far as my fingers can turn it.
Old Aug 15, 2014 | 08:01 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Thanks for the reply, and for sharing...
green hd
Oct 30, 2012 07:45 PM
stokes
Aug 11, 2012 04:29 PM
WhiteNoise
Aug 2, 2012 12:41 PM
DMetcalf
Exhaust System Topics
Aug 5, 2009 01:07 PM
Newhog
May 20, 2008 05:27 AM
