Expensive lesson
Old Aug 9, 2014 | 04:03 PM
UltraZac's Avatar
UltraZac
Default Expensive lesson
Stripped my oil drain plug. Never thought it would happen to me. The dealer was very good about it. They picked up my bike, 2 hours later and my wallet $250 lighter. Most expensive oil change ever.
Old Aug 9, 2014 | 04:15 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Any details? How did you do it?
Sorry for the woes, Bro...
Old Aug 9, 2014 | 04:18 PM
lp's Avatar
lp
I've often wondered if you could weld and then re-tap these.
Just aluminum I think.
lp
Stiggy's Avatar
Stiggy
If its aluminum, I do my best to hand thread any bolt several turns before putting a socket to it, because stripping aluminum threads is so easy to do.
I'm glad you got out of it for only $250. Glad its fixed.
Old Aug 9, 2014 | 04:31 PM
Charlie Fogg's Avatar
Charlie Fogg
I have done that also to a non HD. It was the allen hole on the plug that I stripped. Think dealer over torqued the thing and I ended up stopping it trying to get it out. Sh(t like this happens...
Old Aug 9, 2014 | 04:32 PM
bikerlaw's Avatar
bikerlaw
Next time, head to your local NAPA, they sell PLUS 1, 2 and 3 oversize drain plugs for under ten bucks. They just retap the stripped hole as they go in for the first time. I stripped the oil pan on my old Dyna and had the dealer fix it as well. Very expensive. Then I learned about these damn plus size drain plugs. Live and learn. I guess this is a somewhat common screwup on oil pans.
Old Aug 9, 2014 | 04:35 PM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
They have + size plugs for chamfer seat oring type plugs like the HD?
Old Aug 9, 2014 | 04:36 PM
WARDSPARTSWERKS
How did they fix it for $250.00?
Old Aug 9, 2014 | 06:14 PM
Stang951's Avatar
Stang951
Thats the million dollar question right now.
Old Aug 9, 2014 | 06:21 PM
SeaZund's Avatar
SeaZund
the replacement pan itself is about $100 ($92 plus tax), leaves the other $150 for 2 hours labor, gasket, new plug, fluid? Sounds fairly reasonable..(outta be able to do it in 1 hour I'd think)
