Rear wheel upgrade ...size?
Old Aug 10, 2014 | 06:52 PM
MICROBEAT's Avatar
MICROBEAT
Default Rear wheel upgrade ...size?
I have upgrade the front wheel and now its time to upgrade the rear.
Up front I am running : 21x3.5" Fat wires on 120/70 Wwall
I want to do a 18" rear....but unsure of the width and rear tire size.
Any recomendation, that'll fit the rear stock fenders, and 1" drop brackets.
Many thanks:
Pics would be awesome....
Old Aug 10, 2014 | 08:11 PM
DTTJGlide's Avatar
DTTJGlide
What year RK?
Old Aug 10, 2014 | 08:48 PM
Jumpman's Avatar
Jumpman
If memory serves...
140 tire on Touring models through 2003.
150 tire (may have to trim the belt guard) on 2004-2008.
180 tire on '09-up.
Old Aug 10, 2014 | 09:17 PM
bigskyroadglide's Avatar
bigskyroadglide
04 and up will take a 160 if you cut the bolts down
Only problem is 160 from metzler has lower load rating
If you change the rear fender to 07 se road king rear fender can get a 170/60/17 on a 17x4.5 rim or 180/55/18 on an 18x5.5
You got to run the 1 inch belt with the 180
If you do not want to change the fender a 18 x 4.25 wheel and 150 is abut as wide as you can go
Old Aug 10, 2014 | 09:33 PM
prosnowsk8er's Avatar
prosnowsk8er
Upgraded my swingarm to an 07 and run 150 18"
j09789
Apr 27, 2023 12:35 PM
slickster5150
May 2, 2015 09:58 AM
AllenW
Wheels/Tires
Dec 20, 2012 02:37 PM
62trvler
Nov 7, 2007 06:41 PM
drdave
Jan 20, 2007 09:17 PM
