Still Coughing?
Old Aug 14, 2014 | 03:29 PM
pecostx's Avatar
pecostx
Default Still Coughing?
I have a 98 ultra EFI that has the dreaded and infamous "Kehin Cough". I was under the impression that EFI did away with that hideous malady, yet my ride suffers from frequently and occasionally to the point of stalling. I have been left for almost dead twice in the last few months when my baby coughed and stalled as I was starting to make a left hand turn at an intersection while oncoming traffic had no intention of stopping to let me restart and get out of their way. Worst part was it caused me to almost drop her right in the middle of the street.
She's a stock 80" evo with stage 1 air cleaner, aftermarket slip on mufflers and a power commander PC3-usb. Disconnected the PC3 and she still coughs like a chain smoker. Oh and throttle response is miserable as well. Any ideas on where to start? All of my bikes up to now were carbed models so I am flying uncharted waters here.
Any help is appreciated. Thanks
Old Aug 14, 2014 | 03:35 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Intake seals. A buddy of mine pulled his, because his bike was running the way you describe, and one of them crumbled as he pulled it off the Y. It was a miracle that the thing ran at all. It was a 98 Evo Road Glide.
This is a picture he sent me of his seals.
Old Aug 14, 2014 | 04:48 PM
mkguitar's Avatar
mkguitar
check the evo forum, the magnetti marelli efi was/is a mess. Some of the guys have converted to carb ( I love the keihin and it is easily modded for better power and mpg than the EFI) and some have mastered the MM EFI.
as above start with the basics, the off idle transition seems to be your problem.
if it is sneezing through the intake then look at:
lean mixture
too advanced ignition timing
intake valve not sealed- cam/lifter/pushrod/valve bent/ seat worn etc
mike
Old Aug 14, 2014 | 06:23 PM
BIGRED1's Avatar
BIGRED1
Fuel filter/fuel lines...
Old Aug 14, 2014 | 06:36 PM
Stiggy's Avatar
Stiggy
Just replaced my throttle position sensor last fall when mine did something like that. Fortunately Dealers still have analyzers (back then it was called the Scanalyzer,) that checks your sensors for you. Mine was $65 well spent to find it given that I was 400 miles from home. Might consider it.
Old Aug 14, 2014 | 09:55 PM
BackRoader's Avatar
BackRoader
Mine developed a cough also. Cleaned what looked like a clean k&n filter and found a bad gasket between filter plate and throttle body. No more cough and runs great. Good luck.
djgriff
Nov 30, 2017 04:27 PM
MountainMan75
EVO
42
Apr 19, 2017 10:52 AM
RLH3175
EVO
Aug 16, 2015 08:51 PM
pecostx
EVO
13
Aug 25, 2014 07:16 AM
LucklessPedestrian
Exhaust System Topics
Apr 6, 2008 08:32 PM
