primary leak
Old Aug 15, 2014 | 11:45 AM
fxstc1999's Avatar
fxstc1999
"Wavy" finish is chatter marks left from the machining process to ensure flatness, but sounds like the machinist or CNC program was taking off too much material for the final clean up pass. If you remove the inner primary, check flatness on both sides.
Old Aug 15, 2014 | 03:50 PM
mirrmu's Avatar
mirrmu
hi,
do you know if primary fluid or transmission fluid?
i wouldnt buy any replacement parts until you pull it apart and see where it comes from, you may need puller/installer for inner bearing, or socket for main shaft nut, or it may just be shifter shaft seal
thanks
mirrmu
Old Sep 15, 2014 | 02:52 AM
cweiss's Avatar
cweiss
Update:
Took the bike in last weekend to a reputable shop run by two former Harley Techs.
Inner primary bearing/race, primary to motor gasket, starter o ring, drain plug o ring, derby cover gasket,
outer primary gasket, They replaced the bolts that hold the inner primary on due to the rubber gaskets being toasted. All in all I came out for a little over 300 bucks. I feel ok about it because it isnt leaking anymore.
Old Sep 15, 2014 | 03:06 AM
hog95023's Avatar
hog95023
That's a pretty good price considering the cost of the gaskets, fluid and bearing/ race. Did they upgrade or replace with HD?
Old Sep 15, 2014 | 03:11 AM
cweiss's Avatar
cweiss
Not sure. They were saying that in 07 HD used a much thinner bearing on the baggers and Dynas. To answer your question I dont know. I do know that parts were 140 and change and labor was roughly 200 bucks. Not bad IMO
Old Sep 15, 2014 | 03:15 AM
hog95023's Avatar
hog95023
Beats crawling around on the floor doing it yourself. Especially if you don't have the tools to do it.
Old Sep 15, 2014 | 05:29 AM
Assegai's Avatar
Assegai
$300 is a bargain for that work IMO. Woulda been nice if u could have identified where the leak was. The kneejerk reaction is to put more torque on the fasteners.
Old Sep 15, 2014 | 12:32 PM
cweiss's Avatar
cweiss
Well I just dont really have the time and not to mention dont like guessing at what I am doing. I dont like working on my bike. I like riding it. I work two jobs so in reality I dont want to spend my free time wrenching and attempting to fix stuff...LOL just how it is these days.
Old Sep 15, 2014 | 12:33 PM
cweiss's Avatar
cweiss
Kind of what I was thinking. half of the $ spent was in parts so I dont mind helping a local business that knows what they are doing. I will definately start using those guys in the future.
Old Sep 15, 2014 | 03:40 PM
voodoodrug's Avatar
voodoodrug
cweiss I know exactly what your saying and we have all been there or still there ,for those that can its worth diy for several reasons.
You'll have the 2 special tools for the race and pulley nut(paid 166 for both off ebay) so did the Tran seal and quad seal while i was there for piece of mind and made dam shore the shiftier linkage was torqued well and lock tight on the inner primary race(carefully)....ect,ect.
You'll have the skills to do this (like the u tube video were the guy does it in 30 minutes) and pull the gear cluster next?? with confidence.
You'll wont need to schedule an appt. drop it off.wait,pick it up. and can be more pro active at the first sight/sound of trouble(I waited 30k miles lol)
cacolade
Aug 17, 2017 08:13 PM
bellmnbell
Feb 27, 2017 07:35 PM
Ricky Bobby
Jan 14, 2013 10:57 AM
harleyheaven
Jun 27, 2012 08:55 PM
toadmanor
Jul 9, 2009 09:35 PM
