Brakes
Old Aug 17, 2014 | 10:24 AM
DougnDog's Avatar
DougnDog
Default Brakes
My son inlaw has a 2004 Road king, and has a brake problem. everyday riding the brakes work fine but when on a trip and going to high altitudes the brakes fade, he needs to pump them to get normal braking action. he has stopped and checked the fluid level its good. anyone know what might be going on?
Old Aug 17, 2014 | 10:32 AM
mkguitar's Avatar
mkguitar
could be the seals in the master cylinder.
test:
on a slight slope
apply brakes lightly to hold the bike steady--- using a zip tie is good- as our hand will change it's grip.
and just sit there for a few minutes...does the bike want to roll or will it hold position.
if it moves, the fluid is seeping past the MC seals.
if any part of the system is 'wet' you have a leak.
old fluid will hold water which will react at elevation, change it
if water in the fluid freezes, it may lock up the brakes--- rare on a bike, 'cause who's riding in freezing weather. I've seen this on cars though...poorly maintained cars
mike
Old Aug 17, 2014 | 10:49 AM
grbrown's Avatar
grbrown
Start by flushing out the old brake fluid with new, something we should all do at least every other year. It sounds as if he has a little air in the system, which he has got used to at his normal altitude, but which is affecting braking at higher altitude, with lower atmospheric pressure.
Old Aug 18, 2014 | 10:23 AM
DougnDog's Avatar
DougnDog
Thanks Guys Ill let him know
Old Aug 18, 2014 | 10:24 AM
DougnDog's Avatar
DougnDog
Thank you
Old Aug 18, 2014 | 11:00 AM
rochkes's Avatar
rochkes
I had the same problem last year in the eastern mountains. I was on the road, so stopped at a dealer to have the brakes flushed and new fluid. No problems since.
Dennis
Old Aug 18, 2014 | 09:23 PM
bagman1's Avatar
bagman1
04 used DOT 5, wouldnt hurt to change the fluid. Assuming it hasnt been changed in a while.
Old Aug 18, 2014 | 10:39 PM
Tinman265's Avatar
Tinman265
I agree that the fluid is most likely the problem.
There are other things to check on 10 yr old calipers. Lyndall does a great write up in their tech section about dirty pistons on the older calipers.
http://www.lyndallbrakes.com/service-tech/
Old Aug 19, 2014 | 09:21 AM
DougnDog's Avatar
DougnDog
Thank you all.
cajun1957a
Feb 25, 2019 09:51 AM
Ozark Joe
EVO
17
Jun 13, 2017 11:24 PM
Rollbar
Jan 9, 2015 09:30 PM
hdpearson13
Apr 19, 2008 04:08 PM
softail 99
Aug 16, 2006 01:58 AM
