The Wobble, A Comprehensive Look into Cause, Effect, and Fix
Old Oct 19, 2014 | 05:52 AM
  #121
grbrown's Avatar
grbrown
For all we know there could be a Neracar under that streamlining!
You may recall that Triumph streamliner was destroyed in a fire at the Birmingham museum, a few years ago? While in the USA in 2003 (for H-D's Centenary) we bumped into Bill Taylor, a photographer and regular Bonneville attendee. Apparently the people who made the 'cigar' still had the moulds, so were able to make a fresh one, as seen in your photo.
Returning to front ends, as an engineer I have followed with interest all the variations in Tony Foales article, over the years, plus a few others. Another was a system trialled by BMW before they settled on their current design, designed in Manchester IIRC by a chap named Roe. That was a pair of large diameter tubes with internal shocks and a short leading link each side. I suspect it had limited travel (Roe sold a few sets to private buyers, one of whom I had a long chat with), although they were far stiffer and gave better wheel control than the forks of the day (late 1970s-early 1980s).
I would be very surprised if Howard has an upside-down forks solution that fit any of the RK models. I briefly looked into them as a possibility myself, but concluded that they presented challenges that might be difficult to overcome. If I lived on the same Continent and could visit him easily I would have investigated further.
Old Oct 19, 2014 | 05:55 AM
  #122
grbrown's Avatar
grbrown
Here we go again: Roe front forks. Photos aren't very good, but give the right idea.
Old Oct 19, 2014 | 07:29 AM
  #123
Stretchman's Avatar
Stretchman
I learned something from the Vic forums today. Seems that they too, have some issues with wobble. The new Gunner is notorious for it. Multiple hits when you search over at their forums.
Guess it's more of a bike issue, than a Harley issue.
Old Oct 19, 2014 | 09:28 AM
  #124
Imold's Avatar
Imold
Honda had a similar idea, or maybe they were just watching what Roe did...
Front forks on my Honda Helix scooter. Smooths out the tar strips and little bumps better than the Glide. Reversed from the Roe, shocks on the back side.
I've ridden Hondas and Yamahas that had wobble issues, too. Lot of the early ones had screw down dampers, helped a little. Sometimes...
Old Oct 19, 2014 | 10:19 AM
  #125
Dun Roamin's Avatar
Dun Roamin
On the subject of True-Tracks, is the transmission on the later models the same as the transmission on the Evos?
I see they have changed their design for the rear cage on the '09 model upwards? The later one looks better (forget the frame mount, I know it's different. I know someone selling just the rear cage and wondering if I could just weld a mount to the cross member).
93 - 2008 ...
2009 upwards ...
Old Oct 19, 2014 | 10:37 AM
  #126
grbrown's Avatar
grbrown
Red face
The oilpan gasket on '09s-on is unchanged since 1999, so the hole pattern on that T-T bracket may be different to your bike.
Old Oct 19, 2014 | 10:54 AM
  #127
Dun Roamin's Avatar
Dun Roamin
And yet the old model says, "93 - 2008". That suggested to me '93 to date all used the same - which would not surprise me.
Old Oct 19, 2014 | 10:56 AM
  #128
grbrown's Avatar
grbrown
Red face
Agreed. Could be that the front end of the oilpan is different on later models, hence different gasket, dunnow. Perhaps you'll be fine after all!
Old Oct 19, 2014 | 03:45 PM
  #129
cficole's Avatar
cficole
Originally Posted by cficole
Interesting old video; wonder how the techniques work on an Ultra Classic.
I had to chuckle at "use your loaf" in the last line.
That video is about 40 years old!
I figured. I couldn't decide whether I should feel smart or old, because I was familiar with that expression and its origin.
Old Oct 19, 2014 | 07:29 PM
  #130
Dun Roamin's Avatar
Dun Roamin
Hmmn, I'd say about 35 years, there's a Z1R and a Laverda Jota in there, isn't there?
Do the True-Track allow the transmission to move in a slight but insignificant arc? Isn't there a new one that only allows movement straight up and down?
