The Wobble, A Comprehensive Look into Cause, Effect, and Fix
Old Oct 21, 2014 | 05:18 AM
  #131
grbrown's Avatar
grbrown
Wink
Originally Posted by Dun Roamin
Hmmn, I'd say about 35 years, there's a Z1R and a Laverda Jota in there, isn't there?
Do the True-Track allow the transmission to move in a slight but insignificant arc? Isn't there a new one that only allows movement straight up and down?
They were both introduced in the mid-70s, so almost 40 years!
The stock stabilizers on all Harleys actually move in a slight arc, as does the True-Track and all its cheap copies. However the motion involved is so small that it approximates to a straight line, for all of them. The suspect copies are those that use a very short link, which indicates their 'designers' don't understand what they are messing with!
Old Oct 21, 2014 | 06:25 AM
  #132
Dun Roamin's Avatar
Dun Roamin
Yes, the short links arcing more ... and at one corner instead of the middle.
Old Oct 21, 2014 | 10:57 AM
  #133
foxtrapper's Avatar
foxtrapper
Veteran: National Guard
Originally Posted by grbrown
I would be very surprised if Howard has an upside-down forks solution that fit any of the RK models. I briefly looked into them as a possibility myself, but concluded that they presented challenges that might be difficult to overcome. If I lived on the same Continent and could visit him easily I would have investigated further.
Something I would not mind seeing on a Harley fork is anti-dive tied to the brakes. Honda has played with this off and on, and I've found it to work very nicely on the bigger heavier touring like bikes. Wouldn't do anything for wobble, but would help with control under hard braking.
Old Oct 21, 2014 | 07:18 PM
  #134
Dun Roamin's Avatar
Dun Roamin
Agreed. Could be that the front end of the oilpan is different on later models, hence different gasket, dunnow. Perhaps you'll be fine after all!
True-Track confirmed that the rear cage only will fit but not the frame attachments, so the later ones marked '09 might be consider the later development. YMMV.
Shorter bolts, more circumferential pressure being better?
Old Oct 22, 2014 | 09:09 AM
  #135
grbrown's Avatar
grbrown
Wink
Rubber mount Harleys had a form of anti-dive for many years, as a part of the front air-assisted suspension. My 1990 bike still has it. The handlebars are an air reservoir that supplements the springing in the forks while riding normally, however applying the front brake closes off a valve, omitting the handlebars from the system. The reduced amount of air available stiffens the front suspension while braking, reducing dive. Better damping achieves a similar affect, bearing in mind the fork damping on most Harleys is mediocre.
Old Oct 26, 2014 | 09:21 AM
  #136
Imold's Avatar
Imold
My 89 handled pretty decent, but I think (hope) it could be better; probably has original parts in it, and with more than 120K, probably would improve just with new OEM seals and springs. Forks are in pieces right now, plan is to put single rate springs and intimidators in them, ditch the air (but keep all the parts, just in case...). That reminds me, gotta make some calls and make sure I can get those parts to fit the old Glide.
Old May 22, 2017 | 12:37 PM
  #137
fer79's Avatar
fer79
Checkout video
Old May 22, 2017 | 03:12 PM
  #138
Max Headflow's Avatar
Max Headflow
Not the problem..
Add The swing arm stack holds the plate in place..
Mhoffer
Mar 21, 2018 04:14 PM
