screaming eagle elite breather
Old Aug 26, 2014 | 05:43 AM
hemi1300's Avatar
hemi1300
Sorry no pics, but ended up buying the gloss black elite breather at my dealer this weekend. Absolutely love it so far, looks great and has a nice roar to it under moderate acceleration. Install was a bit of a chore, didn't realize I would have to prop up the gas tank to access a few bolts
Old Aug 26, 2014 | 08:57 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
I would be very grateful to the OP if He bought two of these air cleaners and gave me one of them.
Everyone I meet would hear about what a fine fellow the OP is!
Old Aug 26, 2014 | 09:31 AM
austinslider's Avatar
austinslider
I use a heavy breather with the shorter K&N filter. This allows me to put the lowers back on for the winter months.
Old Aug 27, 2014 | 02:06 PM
wpdjoey's Avatar
wpdjoey
Ok done now i need a programmer have to sneak that past the ol
Old Aug 27, 2014 | 09:39 PM
STLFLSTF_Mike's Avatar
STLFLSTF_Mike
I put the Harley Heavy Breather (looks similar) works great. Really opens the air flow, when I hit the throttle you can hear it sucking the air in! IMHO it's worth the $$$
Old Apr 5, 2015 | 10:05 PM
england7055's Avatar
england7055
Stage II
Default Screaming Eagle Heavy Breather Elite
I have a 12 SG and am getting some serious oil blow by after putting the SE heavy breather elite on. At the same time I had 583 S&S easy start cams w/new lifters put on along with a fueling high volume oil pump. Anyone else had this happen? Any ideas for a fix?
Old Jan 11, 2016 | 01:25 AM
shimaze's Avatar
shimaze
Exclamation Can you use the Elite with lowers?
Originally Posted by willryder
I'm running this one also, like the way it isn't as long. Works great it you have lowers installed.
I always heard you could not run the Screamin' Eagle Heavy Breather Elite with lowers?
It is extremely IMPORTANT to note that there is a difference between the Elite & non Elite Heavy Breather. I have noticed that both breathers are talked about in this thread without specifically noting the difference. This thread is suppose to be about the Elite version!
Old Jan 11, 2016 | 05:08 AM
Hitch2016's Avatar
Hitch2016
My bike is completely stock, new and only has 320 miles on it.
I'm already wanting to get louder exhaust but I don't feel I need the power gain of going full stage 1. Yet, I expect that I'll eventually want stage 1.
My dealer told me that I could just add SE slipons for the louder sound and be done.
Or, if I also added the SE air cleaner, to maintain the warrenty I would need to add a tuner too (thus full stage 1) because otherwise it would run too lean and discolor the chrome exhaust, and not be covered by warrenty.
Are they blowing smoke up my a$$?
Old Jan 11, 2016 | 05:51 AM
msocko3's Avatar
msocko3
Depending on the tuner your dealer recommended, it could also void the warranty. The only tuner Harley sells which won't void the warranty, is the Screamin Eagle street performance tuner. FWIW, you have a bike with a pretty good air intake system right from the factory, on 14 and later it's more looks than increased power with Stage 1 air systems. Now if you're going to change cams or perform other engine modifications, you could get an advantage swapping to a better flowing air filter.
Old Jan 11, 2016 | 06:41 PM
Hitch2016's Avatar
Hitch2016
Msocko3 - thank you for the info. That's good to know. Yep, you're right, it was the SE tuner they were suggesting
