Power vision question
Old Aug 31, 2014 | 08:14 PM
NKy Ultra's Avatar
NKy Ultra
Thanks for the advice.
Old Aug 31, 2014 | 09:40 PM
Rdgray's Avatar
Rdgray
Originally Posted by NKy Ultra
I would like to purchase a powervision from fuelmoto. I have 012 Ultra. Would I have to remove the gas tank to install it. I have the manual, but I'm a little bit nervous about removing my tank.
You do not need to remove the tank. When you bring the wire out from under the side cover at the top toward the tank tie it off there. This will be under the edge of the seat. Then you can route it along up under the edge of the tank toward the front and tie it off at the front of the tank. Take it under the switch cover and bring it out where the rubber is around the bars and up the bars to the PV. Mine has been this way for 1 1/2 years and the wire stays in place.
You will need to remove the switch cover.
Old Aug 31, 2014 | 10:06 PM
SafetyMan's Avatar
SafetyMan
Removing the tank is a 5 minute job...
Do it right, once.
Old Sep 1, 2014 | 09:12 AM
onaride63's Avatar
onaride63
Originally Posted by bkgabby
I've had the power vision on my bike for a few months now. It's running great after doing a few auto tunes. I have run the wiring under the tank and have the display on my bars. My question is, do you guys leave the display up where you can see it and why? After having it there for a while I don't see much use for it. I did monitor temps when it was first installed, but now don't. I would like to clean up the bars.....
I leave mine on. I like viewing the live data when I want... dc volts , engine head temps throttle position, yadda,yadda.
But if you want it clean....take it off
Old Sep 1, 2014 | 01:16 PM
bkgabby's Avatar
bkgabby
Took it off yesterday. I monitored all the temps also but for what, it just made me paranoid at long hot stop and go traffic.. Lol. As for a adjusting stuff on the fly, I wasn't that smart and didn't want to mess anything up. I did leave the wiring under the tank just tucked the end up into the faring.
Old Sep 1, 2014 | 01:53 PM
ThisIsMe's Avatar
ThisIsMe
Do it right, once.
On a 09 and up it is.
PITA with the cross-overs on the pre-09s.
Unless you time it right and are almost empty.
TheGENERAL412
General Topics/Tech Tips
Jun 5, 2018 07:20 AM
SouthpawHD
Apr 17, 2016 11:23 PM
shekmark
Apr 9, 2016 09:30 PM
PPBART
May 16, 2013 12:27 PM
Fenres
Nov 21, 2012 04:57 PM
