Road king 2003
Old Sep 2, 2014 | 02:11 PM
rolfsharley's Avatar
rolfsharley
Default Road king 2003
I have a 2003 road king,my turn signals wont get off Automatic like they shall.Any ideas whats wrong?
Old Sep 2, 2014 | 02:19 PM
August's Avatar
August
Tilt sensor and odometer (speedometer) control turn signal cancellation.
When either the tilt sensor or speed sensor malfunction, an error code is posted.
Start by reading error codes
Old Sep 2, 2014 | 03:14 PM
grbrown's Avatar
grbrown
Have you done any work on your bike recently? On my older bike there is a wire from the back of the speedo to the flasher module, which if disconnected will stop the automatic function. My wire is white/green.
Old Sep 2, 2014 | 05:07 PM
shakrr's Avatar
shakrr
Good luck I have a 02 and have same problem I replaced the speed sensor and the turn and security module which also houses the bank sensor which did not fix Gbrown where was the green white wire at fault at I have a plug for the speedo?
flhrc2009
Electrical/Lighting/Alarm
Nov 17, 2025 12:45 AM
Bama35
Oct 9, 2016 07:37 PM
pp6000v2
Mar 19, 2014 03:41 PM
Beercan321
Nov 9, 2009 02:14 PM
JRenegade13
Oct 25, 2007 06:27 PM
