Oil Leak ?
Old Sep 3, 2014 | 03:28 PM
Warbird40's Avatar
Warbird40
Thank you all for the info, will probably get to it on the weekend.
Old Sep 4, 2014 | 01:30 AM
Warbird40's Avatar
Warbird40
Originally Posted by Nute
Check the Transmission Cover on the opposite side of the bike. Common for oil leak to from these. 5 or 6 allen head screws have a habit of working loose and leaking. Because bike is leaning on stand oil runs across bottom of bike and drips on floor.
Didn't think of this one, thanks. I put apes on it and had to change the clutch cable....will check in the morning.
Old Sep 10, 2014 | 11:26 AM
Warbird40's Avatar
Warbird40
Default It hasn't leaked
Well, for some reason the bike hasn't leaked. I wiped and cleaned the bottom and haven't noticed any drops.....strange
Old Sep 10, 2014 | 01:13 PM
jamesw's Avatar
jamesw
Originally Posted by Warbird40
Well, for some reason the bike hasn't leaked. I wiped and cleaned the bottom and haven't noticed any drops.....stranged
Empty?
Old Sep 10, 2014 | 01:29 PM
baloot-boy's Avatar
baloot-boy
If dealer just did an oil change, then its possible that its leftover oil from removing/replacing the oil filter that finally made its way down. Check fluid levels be sure you arent empty as well.
Old Sep 10, 2014 | 01:37 PM
Warbird40's Avatar
Warbird40
What had dripped was a bit dirty, but oil is still nice and clean. So I think it might have been left over oil from filter change that dripped down and got dirty along the way.
Old Sep 10, 2014 | 01:41 PM
TWIN CAM 96's Avatar
TWIN CAM 96
I bet it's the oil filter drainage from the last filter.
Just spray area with some brakekleen & wipe off & see if it comes back also make sure the filter is snug.
KJB
Jun 6, 2014 06:52 AM
johnpace2
Apr 24, 2012 08:15 PM
TRRcheck
Mar 29, 2010 10:06 PM
daharleyrdr
Jan 11, 2009 07:41 AM
LiLCricket
Sep 23, 2007 02:23 PM
