Put a new filter and regulator in it last night...
Now it will barely run.
What was the problem with the fuel filter assembly?
The plastic tab that holds the metal C clip wasn't engaging, so I put a zip tie on to hold it in place.
I'm going to take it back apart this evening when I get home from work.
Are the parts in the tank the same as the '14s? I don't have an '08 manual, but I do have all 3 manuals for my '14.
Had the same problem with My 08UC. Fuel filter shell was split, and I had it replaced. Change it with a new one if the tab won't engage properly. It will reduce fuel pressure resulting in NO Power.
This makes a lot of sense.
When he first got it to me, the C clip was half out.
