Front Brake Leaking
Old Sep 7, 2014 | 09:17 PM
davidsdad's Avatar
davidsdad
Default Front Brake Leaking
I have a 2011 Road King FLHR (bought new)
What is the fix for the front brake master cylinder leaking around the rubber gasket just under the cover?
I've loosened it and re tightened it, still leaking. I know not to over tighten because that will cause it to leak as well. Thanks.
Old Sep 7, 2014 | 09:21 PM
mkguitar's Avatar
mkguitar
is it overfull?
if brake fluid has been added overtime...then the pads changed...then the reservoir may be overfull.
mike
Old Sep 7, 2014 | 09:23 PM
davidsdad's Avatar
davidsdad
It's not over filled and brake pads haven't been changed.
Old Sep 8, 2014 | 04:43 AM
Hukamosh's Avatar
Hukamosh
My '03 was leaking from the sight glass in the lid, I replaced it and all is well. If your sure it's leaking from the lid gasket and you've tried cleaning and it's not overfull then I'd replace the gasket.
Old Sep 8, 2014 | 05:58 AM
Campy Roadie's Avatar
Campy Roadie
Replace the gasket, that will fix it. Done and done.
Old Sep 8, 2014 | 09:29 AM
navyman's Avatar
navyman
On my 2012 Road Glide the dealer replaced the whole reservoir for a seeping problem. Fortunately under warranty.
Old Sep 8, 2014 | 09:38 AM
TWIN CAM 96's Avatar
TWIN CAM 96
Replace lid & gasket if still leaking replace reservoir
Old Sep 8, 2014 | 12:04 PM
Guntoter's Avatar
Guntoter
H-D does not sell the gasket separately for some reason. Have to buy the cover, which comes with gasket and sight glass.
Old Sep 8, 2014 | 09:04 PM
davidsdad's Avatar
davidsdad
Thanks guys. I guess I'll get another cover and gasket and give that a try.
Old Sep 9, 2014 | 04:56 AM
Charlie K's Avatar
Charlie K
It started leaking on my 2013 Limited as well. Before I could take it to dealer the leak stopped. I have no idea why it started to leak and I have no idea how it repaired itself. No leaking for a few months now.
