Locating wheel chock in trailer
Tongue has to be level when weight is applied.
https://www.etrailer.com/faq-trailertowtips.aspx
If you want to just guess at it and hope for the best, there is always the drill a hole and cross your fingers method. The idea of a "normal/correctly built" trailer is a joke. These things are designed by rednecks with a welder, not engineers.
Whatever.
I have owned at least a dozen boats, ranging from my 12' john boats to 30' cruisers. Not one of them came properly set up on the trailer from the factory. Do you think any random trailer set up exactly the same whether a 250 dirt bike or a bagger?
Add a second bike, your dynamic is off. Wife throws the kitchen sink in her bag on the back of the trailer... or the front, your dynamic is off.
I've also loaded and towed thousands of miles... some in a commercial truck with my CDL, and some in my own trailers, At one point I had to stop the insanity, when I moved from Michigan to Virginia I owned 5 trailers....
The biggest thing to watch, is to make sure you have more weight forward of the apex than behind. It your trailer is tail heavy, it will not follow, and is dangerous.
The formulas above are absolutely correct, but in the real world, can be misleading.
Engineering cannot change nature, nor does it change the dynamic of trailering.
With MOST of the weight forward of the axles, the trailer will pull true.
With ALL of the weight forward of the axles, the trailer will pull true.
The ONLY reason some commercial trailers have slide-axles is to make the axle weight legal for the scales.
It has nothing to do with safety. It's for Profit.
The reason for most private trailers to have the axles more centered is to allow the trailer axles to carry the majority of the weight, due to low bumper capacities of a lot of private vehicles.
As long as the tongue has at least 10 or 15% of the total load, or more, and you do not exceed YOUR vehicle's tongue weight capacity, you'll be fine.
