EITMS 2014 street glide
Old Sep 15, 2014 | 07:16 PM
SafetyMan's Avatar
SafetyMan
Originally Posted by GTK
Safetyman,Is that 280 degrees F.? Anyway,I always leave mine enabled,even though I run a tuner to enrichen the cyls for cooler running,it still comes on in this South Florida heat at long traffic lights in the summer.
80° F ambient air temperature.
Originally Posted by jasnusc
The primary reason for this is Not rider comfort.
This was designed for engine heat management to prevent engine overheating. Rider comfort is an ancillary bennefit that is highlighted in their liturature as a marketing tool.
Documentation please.
I have never read ANYwhere that claims it is to prevent engine overheating.
If it was truly a tool to save the engine, we would not have the option to shut it off...
It only works at idle, and the engine gets hotter when it is NOT at idle. i.e., low speed under load..
Idle and stopped, however, is when the rider notices the heat, and that is when the EITMS activates.
If I'm wrong, I'm ok with that. Somebody show me where I'm wrong, and I'll buy the first round when we get to share some miles.
Old Sep 15, 2014 | 07:17 PM
jstrenn's Avatar
jstrenn
I leave mine disabled also. I live in Phoenix area. In fact, about a week ago I decided to enable it just to see how I liked it. The bike stalled at a stoplight when it turned green. Made me look like a newb who didn't know how to use the clutch. Then started thinking about it and that could be a dangerous situation... I'll leave it off, I'm not worried about the heat.
Maybe if I get stuck in traffic I might turn it on then, but thats about it.
Old Sep 15, 2014 | 07:22 PM
cfreeze's Avatar
cfreeze
[QUOTE=SafetyMan;13218894]It was designed for rider comfort, and beginning in 2014, the parameters changed for it to come on at or above 80°F AAT.
Just wondering(and i've heard this from other ppl)were you get the AAT input from.
The AAT sensor isn't even in the EFI Schematic.
To improve rider comfort on all stock Touring model motorcycles,
an optional heat management system (EITMS) may be
enabled. After being enabled, the heat management system
improves rider comfort by turning off the rear cylinder fuel
injector when all of the following conditions exist:
• High engine temperature.
• Engine at idle speed.
• Low or no vehicle speed.
• Clutch lever pulled in or transmission in neutral.
There is a four minute delay after startup before EITMS will
engage. As the engine maintains idle speed, the rear cylinder
functions as an "air pump," helping to cool the engine. This
continues until one of the above listed conditions is no longer
met, then the rear cylinder fires normally again.
Old Sep 15, 2014 | 07:35 PM
MikeZ's Avatar
MikeZ
I leave mine enabled. It has engaged frequently on hot days. All it takes is a quick twist of the throttle to disengage before moving forward.
Old Sep 15, 2014 | 07:50 PM
SafetyMan's Avatar
SafetyMan
Prior to 2014, it was activated by Engine temperature, and your information above is correct.
Beginning in 2014, it went to AAT. I do not recall where I read the 80° from now, but I can tell you that at 79° AAT reading, it does not activate, at 81°, it does.
From the 2014 Owner's Manual:
https://www.harley-davidson.com/app-...NG/file-6.html
Enabled: The EITMS engine cooling feature automatically activates whenever the vehicle comes to a complete stop and is idling during elevated temperature conditions. When the feature is enabled, it may not activate under cool riding conditions.
Old Sep 15, 2014 | 08:41 PM
xhere's Avatar
xhere
Originally Posted by SafetyMan
It was designed for rider comfort, and beginning in 2014, the parameters changed for it to come on at or above 80°F AAT. I have always left mine disabled... I live in South Texas.
This is my thought also, mine is off..
Old Sep 15, 2014 | 08:55 PM
skratch's Avatar
skratch
i too, remember reading the 80* somewhere, but can't find it now. when the 14s first came out and that was mentioned, i thought the poster was mistaken, then researched it and found it to be true.
also, just because i know how some people are on this site, and your quote doesn't specifically state 'ambient air' only elevated temps (could be engine?) i cut and pasted this from the 2015 owner's manual.....
Old Sep 15, 2014 | 09:22 PM
shore's Avatar
shore
I'm thinking "threshold" does not relate exactly to high engine temps.
Old Sep 15, 2014 | 09:25 PM
ultramotive's Avatar
ultramotive
Once mine came on when the info temp reading was at 75. Unless it wasn't reading accurately at that moment.
Old Sep 16, 2014 | 05:15 AM
Rdgray's Avatar
Rdgray
For 2014
