Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
2015 Tri Glide Clutch to Hard
Old Dec 9, 2014 | 08:47 AM
HDDOC's Avatar
HDDOC
Default 2015 Tri Glide Clutch to Hard
I have a female friend that just bought this 2015 Tri glide that is having a problem with pulling in the clutch, she states its to hard a pull and has short fingers also. Anything out there that will help her out. Thanks Doc
Old Dec 9, 2014 | 07:59 PM
LKHA's Avatar
LKHA
Have her get a stress ball and build up some strength in her hands. The TG has a hydraulic clutch so not much can be done
Old Dec 10, 2014 | 12:59 AM
sloufoot's Avatar
sloufoot
Harley does make a "reduced reach" handlebar. The left grip is only about half the thickness so it makes the reach to the lever less. The only problem I can see is the limited choice of grips.
I don't know of any others on the market. Go to Harley web site & download an accessory catalog, or better yet hit your dealer up for a printed one. Should be free.
Old Dec 10, 2014 | 06:58 AM
HDDOC's Avatar
HDDOC
Thanks Doc.
Old Dec 11, 2014 | 09:09 AM
Mr. Wizard's Avatar
Mr. Wizard
Amazon.com: RSD Regulator Brake/Clutch Lever Set - Black Ops 0062-4004-SMB: Automotive Amazon.com: RSD Regulator Brake/Clutch Lever Set - Black Ops 0062-4004-SMB: Automotive
Find them for your bike and year model. Seems to work well for small hands.
Old Dec 11, 2014 | 07:52 PM
screwball's Avatar
screwball
Not sure if it will help with the hydraulic clutch, BUT with wife's '09 and '11 trikes she had a hell of a time with the clutch pull. Chemotherepy did a number on her hand strength. Our local dealer knew she had a 96" Deluxe and had no problems with that clutch. They removed the clutch spring on her trike and replaced it with the lighter spring for the 96cid engine. Problem solved!! She says she doesn't have a problem with her '14 trike, guess she has increased the strength in her hands. Good Luck!!
Old Dec 11, 2014 | 08:14 PM
Mr. Wizard's Avatar
Mr. Wizard
The hydraulic clutch is the new style Slip'n Assist clutch. It doesn't have a replaceable diaphragm spring. There are three compression springs. To my knowledge there is no aftermarket replacement springs to stiffen or reduce the clutch disc down force.
Old Dec 12, 2014 | 10:57 AM
HDDOC's Avatar
HDDOC
Thanks for the help, she thinks maybe that the reduced levers may help. Up to her . Thanks Doc
Old Dec 12, 2014 | 10:32 PM
TrapshooterBob's Avatar
TrapshooterBob
http://www.kuryakyn.com/Products/121/Boss-Blades
P/N 1723 with the Harley low model thinner grips is about as good as it can get!
Bob
Old Dec 13, 2014 | 09:56 PM
Diamond lil 2010's Avatar
Diamond lil 2010
I noticed when I bought my 2015 the clutch is hard to pull I came off of a BMW you could pull that clutch with 2 fingers any hydraulic clutch that I've ever pulled has always been a one to two finger pull I don't know why Harley Davidson hydraulic clutch is so hard to pull
