Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Is the Ultra supposed to clank when you shift?
Old Sep 5, 2015 | 11:55 PM
rvnkontum's Avatar
rvnkontum
Originally Posted by screwball
Every Harley I've ever owned starting with my 1970 Iron Head clunked when you put it in gear. If I ever got a Harley that didn't I'd worry.
Ride it in good health
My bikes have also always "clunked", but this is more like two metal rods banging against each other.
Old Sep 5, 2015 | 11:57 PM
rvnkontum's Avatar
rvnkontum
Like to thank everyone for their advice, sounds like changing the transmission fluid might be the way to go, now all i have to do is learn how to do that.
Old Sep 6, 2015 | 07:53 AM
cochon's Avatar
cochon
So far, in my 2012 Tri, I've tried Amsoil Severe Gear, Harley Syn3, BelRay, Golden Spectro, Lusas Oil and RedLine. The RedLine seems to have worked the best for me and I will soon change back to it. That has not been the case for all of my friends. Some prefer Amsoil, some prefer Golden Spectro, almost nobody recommends Syn3. It seems to me that every tranny is unique and if you can find something that works for you stick with it. I know I'm going with Redline.
Old Sep 6, 2015 | 10:41 AM
JimmyDee's Avatar
JimmyDee
Although my '13 Limited does it, my '13 TG does it except louder. I took it to the dealership and they said it was the compensator. Wasn't satisfied so I took it to another dealership and was told the same thing. Then I thought that I would see what an independent's diagnosis would be. Summary: 3 answers and all were the same and there was no problem.
My TG would be especially noisy if I let off the gas and immediately re-applied power. We came to the conclusion that the louder noise might stem from the TG being a heavier bike.
No need to ask why because I don't have a clue. When in neutral and you are backing your bike out for a ride, hold in the clutch. After your ride has warmed up, when you put it in gear there is no 'clunk'. Also will do this on my other Harleys.
Old Sep 6, 2015 | 10:55 AM
Ray on the drums's Avatar
Ray on the drums
It's a bad *** sound don't fight it!
Old Sep 7, 2015 | 06:06 PM
NHBAGGER's Avatar
NHBAGGER
My 14 does it pretty loudly. So far we have changed tranny fluid, primary fluid, went to a Baker manual adjuster and checked the compensator shims. no better.
Old Sep 9, 2015 | 10:03 AM
Lighteye's Avatar
Lighteye
My 2015 Road King with just under 800 miles on it clunks at every shift into every gear. My C50 Boulevard that I traded in for this was silent, but you could feel the shift occur. This bike? The car driving next to me can hear it. Freaked the wife out, she thought it was falling apart. It sounds like 2 metal rods banging into each other.
Old Sep 9, 2015 | 02:23 PM
Steve On 3's Avatar
Steve On 3
Mine did it when getting on opr off the gasd. dealer replaced the compensator and noise went away. yours is under warranty. have it checked. if it isnt the comp, you haven't lost anything.
Old Sep 10, 2015 | 07:14 AM
cochon's Avatar
cochon
It has been said many times on this forum that you should get the factory service manuals. Changing the tranny oil is simply a matter of removing the drain plug and the filler cap, so. it should be easily within your abilities if you have any mechanical aptitude at all. Good luck.
Old Sep 10, 2015 | 11:54 AM
CaCruizin's Avatar
CaCruizin
Mine has now got Belray transmission oil and it is soooo much quieter!
