Traded in my '14 Limited for a '15 Triglide about four weeks ago, never had or ridden a trike before, so, as a novice, just like to know if it's supposed to make a clanking sound when I upshift or downshift? It also makes a similar sound when I decrease or increase throttle. Is it normal, or should I bring this to the dealer's attention? I've got about 1,400 miles on it. Thanks!
TriGeezer
close
- Join DateMay 2012
- LocationCarlsbad, CA
Liked:36,028 Times in 13,142 Posts
That's how you know you successfully shifted it. But, a better tranny lube helps it run smoother. I've gone to Belray in the transmission and shifts are smoother and not as clunky.
Fearless (old nickname)
close
- Join DateNov 2013
- LocationClarion PA.
Liked:115 Times in 103 Posts
Better oil in the tranny worked for me
fearless
Every Harley I've ever owned starting with my 1970 Iron Head clunked when you put it in gear. If I ever got a Harley that didn't I'd worry.
Ride it in good health
hardheaded
close
- Join DateOct 2012
- LocationSt.Louis Mo.
Liked:3,040 Times in 1,831 Posts
they all do that ! if it didn't i would be looking for the problem. good trans gear oil helps alot.
ExploreTriGeezer
close
- Join DateMay 2012
Quote:
Probably not at 1,400 miles.Originally Posted by riden2low
compensator noise?
