Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
S&s 557 (330-0053)
Old Sep 16, 2015 | 04:29 AM
Fusionfool's Avatar
Fusionfool
Default S&s 557 (330-0053)
I am thinking of going to the S&S 557 (330-0053) CAMS
http://www.sscycle.com/product/557-E...it-p24006.html
Do any of you have these in your Tri Glide, and what are your thoughts after some miles on them?
I would be going with Quicky push rods, and leaving my setup as is with V&H power duals, and Rush Big Louie 2" exhaust.
Thanks in advance for sharing your experience.
Old Sep 18, 2015 | 04:09 AM
msocko3's Avatar
msocko3
Why the Ez start cam when you have ACR's, obviously you've looked at the TTS-100 cam.
Old Sep 18, 2015 | 07:13 AM
Fusionfool's Avatar
Fusionfool
I could not find any info on the TTS-100 cam's except what is in this and other forums. I could not find anything except call TTS.
What is the RPM on / off range for them?
I am no expert on this stuff, but talked with S&S about bolt in CAM's and they stated the 330-0053 (557 Cams) were developed specifically for the TG with great low end torque and no sacrifice to the range of riding I described.
I ride up to about 4000 RPM on occasion, normal around 3K but would like to lower that to have CAMs kick in much lower. I ride a lot of hill country and mountain like Smoky Mt, and Bear Tooth out west. I am looking for easier start from dead stop without sacrificing too much on interstate 80+
I am still looking for the true range of the 557 stated RPM on / off.
As for easy start, it was along for the ride, not that I need them.
I appreciate your help and comments.
Old Sep 18, 2015 | 09:33 AM
Fearless (old nickname)'s Avatar
Maybe PM the Wizard he seems to know about this sort of thing. I followed the developement of the TTS 100 cams talk to the Wiz I'm sure he would not steer you wrong. he can answer your questions. ride safely fearless
Old Sep 18, 2015 | 12:32 PM
Mr. Wizard's Avatar
Mr. Wizard
TTS will not give out the specs of the cam.
Let's just put it this way. If they weren't better than what I had before they would not be in my trike. I can pull away as low as 1500 RPM if I want. I've hit redline at 6200 and they were still pulling. Just say'n.
Read about the others who have installed them. Don't take my word for it. What do they say?
Old Sep 18, 2015 | 03:21 PM
msocko3's Avatar
msocko3
Here is a dyno sheet on a 2 wheel bike, the guy who tuned it doesn't play number games. He tuned my 06 Ultra so I know him 1st hand and found him to be a straight shooter and a heck of a tuner.
Old Sep 21, 2015 | 08:38 AM
Fusionfool's Avatar
Fusionfool
Thank you for the feed back. So with my Power Vision Tuner, if I go with the TTS-100's is there enough data to get a basic start tune for my setup.
V&H power duals, Rush Big Louie 2" baffle, and Big Sucker AC?
Thanks again....
Old Sep 21, 2015 | 03:54 PM
msocko3's Avatar
msocko3
Thanks again....
I have to believe there is someone out there with a PV that has a tune for these, you might check with either Dynojet or Fuelmoto.
Old Sep 22, 2015 | 12:27 PM
Fusionfool's Avatar
Fusionfool
Ok between communication with Steve Cole, and DynoJet I have a base tune for my setup with anticipating the TTS-100 CAMs. Now just waiting for TTS to get some inventory and ship. Looks like they are about 2 weeks out.
Thank you all for all of your help. It sounds like I should be exactly where I wanted with the TTS CAMS.
Old Sep 22, 2015 | 12:41 PM
Mr. Wizard's Avatar
Mr. Wizard
Good move
