Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Wire extensions
Old Mar 18, 2017 | 09:29 AM
Casper's Avatar
Casper
Question Wire extensions
Got a stupid question, although I've probably exceeded my stupid question quota!
Putting new bars on the new trike, ordered wire extensions this time around to ease install and my mind. The extensions just plug into the wire ends inside the fairing, correct?
Just want to make sure I'm doing it correctly
Thanks all
Old Mar 18, 2017 | 11:22 AM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Yup, unplug the bar wires from the jacks inside; change out bars. Put the bars back on, plug the plugs into the extensions and the extensions into the original jacks and you're done.
Old Mar 18, 2017 | 11:39 AM
Casper's Avatar
Casper
Thanks buddy
Old Mar 18, 2017 | 02:31 PM
8Crow's Avatar
8Crow
Not sure if the wiring is different for the TBW between the '17s and my '13 and if there is disregard...
On mine when I changed the bars, the TBW sensor had a small connector inside the bars that was accessible when you removed the sensor on the OEM bars. The lower part of the harness then fed through to inside the fairing to a larger connector. Be careful when you disconnect the small connector that is inside the bars as the latch breaks very easily... I know...
Good luck with your change out.
Cheers
Doug
Old Mar 18, 2017 | 09:02 PM
Casper's Avatar
Casper
Cheers
Doug
When I did my 16 I was surprised that there was not a green connector on the TBW...
Old Mar 19, 2017 | 09:22 AM
Fearless (old nickname)'s Avatar
Default Replacement and newer no green gremlin
Harley I believe did away with that nightmare in 2014 and replacement units possibly before that I changed mine without breaking it added a little dielectric lube to keep water out. ride safely Fred
Old Mar 19, 2017 | 10:03 AM
30glock's Avatar
30glock
What bars and size are you going with?
Old Mar 19, 2017 | 12:15 PM
Casper's Avatar
Casper
Paul Yafee 10" apes, 1"
JHC210
2014-2024 Touring Models
11
Aug 29, 2016 12:48 AM
Powertrip240
27
Mar 16, 2016 07:38 PM
bpd138
Jul 19, 2014 01:08 AM
ronherman
Apr 4, 2013 06:07 AM
2006FLST
Apr 5, 2010 09:05 AM
