Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Loud pop in rearend
Old Sep 29, 2017 | 08:00 PM
usmc68's Avatar
usmc68
Default Loud pop in rearend
While on a trip to Mackinaw Island this week I was letting trike back down a small grade in a parking lot .the engine was off , in netrual and I heard a loud pop it does it every time I back the trike up running or off makes no difference It pops everytime it makes a belt rotation does fine going forward drove it over 1000 miles back home without having to backup but it still has the pop when I backup ...any help with the problem solving would be a great help .Thanks
Old Sep 29, 2017 | 10:07 PM
sloufoot's Avatar
sloufoot
Have the belt & sprocket alignment checked. The belt may be trying to climb the sprocket Also could be something getting caught one way in the belt.
Old Sep 30, 2017 | 06:52 AM
ISP-FLHTK's Avatar
ISP-FLHTK
Does it only do it when you apply some rear brake? I was getting a bad noise when letting mine roll back, either free wheeling or in reverse. It was a rear rotor that was hanging up. Mechanic just had to clean the mounting pins up and lube it a little and problem solved.
Old Sep 30, 2017 | 10:25 AM
usmc68's Avatar
usmc68
the sprocket the belt runs on has ALOT of side to side play in it . I guess I will tear it down and see if the isolation bushings have come out . Not looking forward to this job any tips to ease the pain is accepted.
Old Sep 30, 2017 | 10:34 AM
rhino 2's Avatar
rhino 2
Jose Cuervo Tequila.........The large bottle.......
Old Sep 30, 2017 | 04:46 PM
usmc68's Avatar
usmc68
Markers Mark to start off with .This is gona be a pricey fix I'm sure .I will do it myself and it will be done right I hope . I don't trust dealer to do it right .
Old Oct 1, 2017 | 12:35 AM
sloufoot's Avatar
sloufoot
Very possible the isolators are worn out. But seems that would pop both ways.
Makers Mark 46
Old Oct 1, 2017 | 08:52 AM
cochon's Avatar
cochon
Last summer, the bearing in the sprocket failed on my 2012 triglide. A symptom of the failure was excessive side play in the sprocket, and when I put a pry bar to it, there was a lot of up and down movement also. As a direct result of this bearing failure, I lost the bearing fit on my differential. To fix it, I had to pull the body, pull the axles out, remove the rear end, buy all the bearings and seals, a new rear sprocket, and a new differential. I did all the work myself and saved a bundle of labor costs.
Old Oct 1, 2017 | 09:17 AM
cochon's Avatar
cochon
Default This
I believe that the cause of all the problems was that the $1.00 snap ring that retained the sprocket broke and everything else was a chain reaction to that failure.
Attached Thumbnails Loud pop in rearend-img_0182.jpg   Loud pop in rearend-img_0187.jpg   Loud pop in rearend-img_0190.jpg   Loud pop in rearend-img_0192.jpg   Loud pop in rearend-img_0197.jpg
Old Oct 1, 2017 | 10:01 AM
cochon's Avatar
cochon
I found that Surdyke had the best price for me on the sprocket and differential. I got the best price on SKF American made bearings and seals on eBay.
