Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Fixed reverse
Old Jul 26, 2018 | 10:48 AM
so60's Avatar
so60
Default New Castle
New Castle has this listed under their parts list:
Part number 31400129 Motor RVS kit. Shows 2 on hand. Price shows $239.28!
Old Jul 30, 2018 | 02:02 PM
tenn.vol.'s Avatar
tenn.vol.
Now so60, that is information that one can use, Thanks from all.
tenn....
Old Aug 2, 2018 | 12:34 PM
Bikerjw51's Avatar
Bikerjw51
Stage II
Mine has just acted up; push the button and only the solenoid clicks. I just turned 12k on my 2012 Tri. So the motor is easy to rebuild? Maybe I'll try it; or just spray the crap out of if with electric cleaner.
Old Aug 2, 2018 | 02:27 PM
Superdave69's Avatar
Superdave69
The brushes are spring loaded. You might be able to just pull the back off and check them .As mentioned before be careful with the type of lube used. I was able to get the motor off by pulling the right side wheel and using a long extension. It's a simple job and will save you a lot of money if you can do it yourself .
Old Aug 3, 2018 | 11:12 AM
wijr1949's Avatar
wijr1949
The brushes on my 2011 were stuck like you described so I did the same thing.
Cleaned and lubed the holders and everything was good for about 6 months. Then it failed again.
I got a rebuild kit from Terry's Components for about $270.
Put that in and all is well.
Old Aug 3, 2018 | 09:01 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
That might just be the breaker has popped open, you might want to try resetting it before spending any money.
Old Aug 4, 2018 | 03:35 PM
Clint44's Avatar
Clint44
What parts are in the rebuild kit?
Old Aug 4, 2018 | 07:09 PM
so60's Avatar
so60
Default HD Kit
I am not sure about the Terry's kit, but according to the info in post 8 above the HD kit: "It is a kit with new armature, brushes, coils, bearings, basically everything but the hard case on the outside."
I can't find the instructions PDF online anywhere.
Old Aug 5, 2018 | 03:07 PM
SpringerRider's Avatar
SpringerRider
If I had to lose one feature from my Trike for the rest of its life, I would sacrifice the electric reverse. In a year, with 10K miles, I have rarely used it. It is actually easier for me to push back my Trike than my 2 wheelers.
Old Aug 5, 2018 | 04:33 PM
hardheaded's Avatar
hardheaded
I think i have used my reverse maybe twice since buying it july 2015. I normally just put one foot down and push it backwards.
