Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
What is the performance like on a Tri Glide?
Old Aug 30, 2019 | 01:42 PM
martin10's Avatar
martin10
Default What is the performance like on a Tri Glide?
Getting older and might consider one in the future. The only performance data I could find was really bad. And was for a 2011 model. 7.5 zero to 60 and 15.5 quarter mile. Thats about what my 4cyl compact SUV does. I realize they are heavy. But didnt think it would be that bad. How is the M8 with the 114? Thanks
Old Aug 30, 2019 | 01:51 PM
RFG7680's Avatar
RFG7680
I can tell you my 19 Freewheeler with the 114" walks all my buddy's stage 1 103 limited. Thought I'd turn off the traction. Control and do a little burn out. Was pretty surprised when the front end came straight up. I'll bet money you're not disappointed with the 114" Stage 1 numbers are right at about 100hp and 126tq from what I found on the internet. Ut just cause it's on the internet dont make it true. Go test ride one.
Old Aug 30, 2019 | 01:53 PM
martin10's Avatar
martin10
That sounds encouraging
Old Aug 30, 2019 | 03:09 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
I've not done any timed runs...sounds like fun...might do it. If I do, will post up the numbers.
In the meantime, with a few minor mods, they can move out as seen in the following vids-
__________________
DKCustomProducts.com
Call/Text: 662-252-8828
Open House Details
Old Aug 31, 2019 | 03:57 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
My dealer suggested a Stage 2 when I bought my 2019. I told him I'd try it stock for a while first. I find I have plenty of power. Lots of torque. I love it stock!
Old Aug 31, 2019 | 11:00 PM
2AMGuy's Avatar
2AMGuy
Community Influencer
No matter how much power you have, a some point in time you'll probably wish you had more!
I have an '18 Tri-Glide with a Stage I upgrade and most of the time it has plenty of get up and go but like any other bike (or vehicle) inclines will take a little more time so you have to drop a gear (or two) and slow down to a reasonable speed.
FWIW, my best MPG's are best between 2500 to 2800 RPM's.
At 3,000 RPM's the MPG's start dropping rapidly and cruising at 75 MPH puts me between 30-32 MPG (on level ground) and any inclines sucks down more fuel.
I had thought about a "torque" cam but I can only imagine the loss of MPG's.
I would have preferred a "taller" 6th gear ratio but I suppose there are others who need the lower ratio.
This trike reminds me of my '00 Ultra with a 5-spd. transmission that had me at 3500 RPM's at 80 MPH.
Old Aug 31, 2019 | 11:30 PM
IdahoHacker's Avatar
IdahoHacker
The Tri-Glide and FreeWheeler have the exact same motor that every other touring model has. The difference in performance is strictly due to the weight: The TriGlide weighs around 1,200 and the FreeWheeler around 1,100. A regular touring bike is around 850, 950 with a tourpack.
I ride with some guys with TriGlides. They'll run your *** off if you don't know how to ride. Trust me, a simple stage 2, cam plus a/c plus exhaust, and a tune, and you'll be more than happy.
Old Aug 31, 2019 | 11:51 PM
DK Custom's Avatar
DK Custom
Platinum Sponsor
Additionally, they are geared lower than the 2 wheelers.
Old Aug 31, 2019 | 11:57 PM
IdahoHacker
Correct, forgot to mention that. When my father in law and I are side by side, he's running a bit higher rpm than I am.
Old Sep 2, 2019 | 05:21 PM
Clint44's Avatar
Clint44
I bought a new 30 tooth front pulley for our trike, a few years ago, and still haven't installed it. Here in Texas, our speed limits range from 75-85mph on our four lane roads, even a lot of our two lane roads are 75mph. Right now, with a 32/68 pulley combo and a 25" rear tire, I'm seeing around 2900 rpm on the tach, at 80mph. With the 30T front, that number would closer to 3500 rpm. If I do decide to swap pulleys, I guess I could always go with 26" tall rear tires, to reduce the overall gearing a little bit.
Cnyflhx
Milwaukee Eight (M8)
Nov 1, 2017 07:22 PM
kjpope
13
Mar 1, 2012 06:23 PM
CYCLE
Apr 4, 2011 09:43 PM
Rick Lees
Sep 21, 2010 07:37 PM
Tri glide 10
16
Jan 8, 2010 10:48 AM
