Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Down Shifting
Old Sep 25, 2019 | 01:14 PM
sawblade54's Avatar
sawblade54
Default Down Shifting
Hi, this is my first Harley, a 18 triglide
Most of the time I downshift while slowing down, but once in a while I come to a complete stop first.
when this happens, she wont downshift past 3rd unless I use my foot to move the bike back a little..
my dealer says this is normal and there is no problem...
the warranty is up in December, so I’m a little concerned if this is true or not or Should I take it too different dealer.
Old Sep 25, 2019 | 01:40 PM
Tuck1991's Avatar
Tuck1991
Dealer is correct. You should downshift to first before you come to a complete stop. You can go back and forth between first and second to find neutral when stopped but that's about it. Smarter people than me can explain the actual mechanics involved.
Old Sep 25, 2019 | 01:44 PM
BrandonSmith's Avatar
BrandonSmith
Active Streak: 30 Days
You typically should let the clutch lever out (at least partially out) between each gear. When you pull the clutch lever in, the gear set eventually stops moving and the dog won't pick up the next gear and you're stuck in limbo until you let the clutch out to start spinning the gear set again.
If you find yourself improperly shifting like that, and you're stuck in a higher gear, let the clutch lever out some, downshift, let clutch lever out, downshift, etc.
Old Sep 25, 2019 | 05:50 PM
RCUltra's Avatar
RCUltra
The HD transmission doesn't have synco's like a car transmission. It can only shift up or down if the two gears you are trying to mesh together line up. If they don't, you have to move a little so they do. If you downshift wile coming to a stop, you are moving and there isn't an issue. The lack of syncro's is why these bikes can also be a bitch to find neutral.
Old Sep 26, 2019 | 06:21 AM
sawblade54's Avatar
sawblade54
Thanks, makes sense and I’m now not worried about it
Old Sep 26, 2019 | 06:32 AM
BrandonSmith
Nothing to be worried about, the transmission is working the way it is designed. Just learn how to shift it properly.
Greg Di
Jan 20, 2017 12:22 PM
295318Lvmyks
Jun 12, 2015 08:37 PM
Mav
Nov 19, 2010 06:11 PM
TRRcheck
May 12, 2010 10:01 AM
Trojan63
Feb 11, 2008 08:18 PM
