Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Reverse motor
Old Jun 27, 2020 | 08:00 PM
kblhd's Avatar
kblhd
Default Reverse motor
Anyone have this issue with the motor separating from the housing?
Old Jun 28, 2020 | 01:09 AM
sloufoot's Avatar
sloufoot
When the motor doesn't back all the way out of the ring gear and you drive it anyway it takes the motor to extreme RPM's and something has to give somewhere !
When you back-up let off the reverse a few feet before you stop so the drive can back out of the ring gear. If the trike doesn't roll freely forward after reverse bump it back and forth until it frees up.
Old Jun 28, 2020 | 06:19 AM
bronxbill's Avatar
bronxbill
I had a 2011 Triglide that lost the reverse motor on a trip to WV. I heard a loud bang and saw the motor laying in the road.
Old Jun 28, 2020 | 03:52 PM
kblhd's Avatar
kblhd
Going to see how the extended warranty works.
Old Jun 28, 2020 | 04:08 PM
470004's Avatar
470004
You may want to consider a mechanical reverse.
Old Jun 29, 2020 | 12:10 PM
kblhd's Avatar
kblhd
I’m the mechanical reverse when it doesn’t work!
Old Jun 30, 2020 | 07:11 AM
foundryratjim's Avatar
foundryratjim
I have a different problem with mine. My battery was getting bad, not holding a good charge and slow cranking on starting, It was five years old and had been kept on a battery tender every winter. I ordered a new Deka. While waiting for the new one I needed to move the trike out of the garage to make room for a project. The reverse motor engaged started to move but wouldn't move the trike, It acted like it wasn't getting enough power. I checked and the breaker was blown also. I figured it was do to the bad battery. I got the new battery and the bike really cranks over now but the same problem exists with the reverse motor. Any ideas? When i get some time i will have to dig into it. 2015 Freewheeler.
Old Jun 30, 2020 | 03:46 PM
Clint44's Avatar
Clint44
A good shop that rebuilds starters, alternators, etc can also rebuild the H-D reverse motor. With parts and labor, expect to pay around $100-$200 or so. Before removing the motor, I would take a rubber mallet and give the motor body a few good thumps. If the problem is just stuck brushes, that very well might take care of the problem, at least for awhile. However, if the motor is not rebuildable and out of warranty, I would seriously consider installing a mechanical reverse.
My Champion mech reverse has worked very well, with no issues in the five years since being installed.
Old Jun 30, 2020 | 07:00 PM
LoanerRider's Avatar
LoanerRider
My prior trike had a mechanical reverse. I just got a Freewheeler with the electric reverse. I probably only used the mechanical reverse 5 times in a year. I don’t plan on using unless necessary. Come on. Man up use your feet. That’s what they’re for.......
Old Jun 30, 2020 | 07:09 PM
Oogie Wa Wa's Avatar
Oogie Wa Wa
Originally Posted by foundryratjim
...... I got the new battery and the bike really cranks over now but the same problem exists with the reverse motor. Any ideas? .....
When the trike didn't move much the reverse motor wasn't turning much, and that basically turns a DC motor into almost a dead short. At least for a second until the breaker finally tripped. That probably partly burned the commutator surface where the brushes were making contact. That would be resistance to getting full voltage now. Just a guess, but I've seen stuff like that with brush-type DC motors that have encountered low voltage on startup
