Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Trike + 4 inch mufflers
Old May 31, 2012 | 07:30 PM
skeeter 250's Avatar
skeeter 250
Default Trike + 4 inch mufflers
Does anyone know if 4inch mufflers will fit on a 2012 TriGlide? A friend of mine says no problems. My concern is the facia cutouts rubbing. Anyone else know?
Old May 31, 2012 | 07:38 PM
tjmac49's Avatar
tjmac49
skeeter 250: I have 4 inch Reinhart slip-ons on my 2012 Tri-Glide. Had similar concerns. No problems. Good luck.
Old May 31, 2012 | 07:52 PM
skeeter 250
Cool, thanks for the reply. I have the mufflers in the garage, ready to go on when I get time. Did you do anything with the header pipe?
Old May 31, 2012 | 08:29 PM
dondee's Avatar
dondee
Uh, I thought they came with 4" mufflers. At least that's what I thought I got when I put a dial gauge on the fat part.
Did I mis-measure?
Old May 31, 2012 | 09:50 PM
skeeter 250
Thanks for measuring them. Now I'm curious. I think I'll measure mine. Duh.
Old Jun 1, 2012 | 04:12 AM
oldmsocko's Avatar
oldmsocko
I don't know about the 2012 but my 09 came with 3" on it. I replaced them with the SE 4" and have no problem with them hitting the body.
Old Jun 1, 2012 | 05:22 AM
CADOO's Avatar
CADOO
I have the V & H Monster Rounds and they are four inch and no problems here. I also have the lift kit on and have not scraped yet.
Old Jun 1, 2012 | 06:01 AM
Noble Jim's Avatar
Noble Jim
Mine has Cobra Tri Ovals. They did drag on some humps, however the lift brackets solved that problem.
Old Jun 1, 2012 | 07:30 AM
bjsfla's Avatar
bjsfla
Cool
Rinehart True Duals & Rinehart 4" Mufflers, NO problem with body clearance, but they will drag tips in some cases....need to install lift kit
Old Jun 1, 2012 | 10:25 AM
TUFF-IRON's Avatar
TUFF-IRON
Vance & Hines 4" turn down slip ons no problem with the body and no drag with the lift kit,
