Tri Glide, RG3 & Freewheeler Models Freewheeler, RG3 & Tri Glide Enthusiasts. Here is your section of the forum to discuss Harley's Trikes!
Clutch Adjustment @ 500 miles?
Old Jul 11, 2012 | 06:45 PM
flagirl's Avatar
flagirl
Default Clutch Adjustment @ 500 miles?
Has anyone needed the clutch adjusted at anything less than 500 miles?
I was heading home from a ride a few days ago, going about 60-65 in 6th. Start to slow down since I was coming into town. Go to downshift, it wouldn't shift. The entire shift lever was locked or frozen. I could pull in the clutch, no shifting. Stopped at the light, was able to downshift to first. Go to pull away from the light, I had to go almost wide open throttle to get going.
Managed to limp home (was about 100 miles away) but couldn't go any faster than 50ish or so and the trike would not stay in gear. Bring the trike in to Harley, they said the clutch needed major adjustments.
This was my third new harley and I've never had that happen before where the clutch needed adjusting with so little miles. I know the adjustments are made at about 1k miles but I was surprised with just over 500 miles the clutch needed adjusting. The trike is just about 3 weeks old and never sat idle for more than a day or so.
The sales guy said he never heard of that happening before but the service tech said it happens "from time to time".
I was just wondering if anyone ever heard or had a similar experience.
On the upside, it's a heck of a lot easier to find neutral now!
Old Jul 11, 2012 | 06:51 PM
dyna105's Avatar
dyna105
400 miles, service tech said lock nut was left loose from factory. Always shifted fine would just slip under throttle in 3rd and 4th.
Old Jul 11, 2012 | 10:49 PM
pettifogger1's Avatar
pettifogger1
Cables stretch, parts seat themselves, etc. No big deal, very easy to adjust. If you own a Harley, you need to know how to adjust the clutch.
Old Jul 12, 2012 | 06:05 AM
msocko3's Avatar
msocko3
Never had a clutch need adjusting before its service, there are a good many times the clutch doesn't need messed with at all. Initially a clutch will need adjusted due to cable stretch and parts seating.
Old Jul 12, 2012 | 07:20 AM
Rox's Avatar
Rox
If you're talking the clutch cable, not the clutch itself, I've had all my bikes, Kawasaki, Road Star, Ultra and Trike need clutch cable adjustment within 300 miles when I got them, all new. The cable will stretch, but normally after this first adjustment (easy to do), they all seemed to stablize.
Old Jul 12, 2012 | 06:53 PM
icebite1's Avatar
icebite1
Heres the thing with the clutch cable, if it streaches it would mean you would have trouble disengaging the clutch. flagirl actually needed clutch plate adjustment unless of course the clutch cable was tight,tight.
Old Jul 14, 2012 | 05:39 PM
frang413's Avatar
frang413
Heck your lucky.At least your dealer knows a clutch can be adjusted.Mine told me last year there is no way to adjust a clutch when i complained about how hard it was to hit neutral.
Old Jul 14, 2012 | 06:54 PM
flagirl's Avatar
flagirl
Well, brief little update. I'm up in Daytona with friends, did another 300 miles on the bike. I'm on 95 heading south about 30 miles away from Destination Daytona and this time, the same thing happened - lost ALL power to the transmission, bike wouldn't shift AT all.
Manage to get to the right lane and slow down enough to get off on the shoulder. Turn off the trike, let it sit, start it up, no power going to the transmission at all! I had to get the trike towed to Destination Daytona.
Long story short, the clutch plates were totally burned and needed replacing. The service tech accused me of not knowing how to ride, until I clarified that I had over 15k miles between 2 former Harleys before I got my trike.
Long story short, the theory is that somewhere along the line, the clutch was not properly adjusted the first time, or the dealer prep before sale wasn't done properly. Let's hope there will be no more problems.
Old Jul 14, 2012 | 07:48 PM
oldmsocko's Avatar
oldmsocko
I'll bet you a dollor to a hole in a donut the dealer did no prep at all before delivery.
Old Jul 16, 2012 | 09:14 AM
dougbk's Avatar
dougbk
My gal had the same problem with hers and lost the clutch at under 500 miles. Orginally the service writer tried to blame her and say it was a wear item. I called BS and told him I fully understand what a harley clutch is capable of from using them on the police motor course and there is no excuse for a clutch going out at under 500 miles under normal riding conditions. They fixed it under warranty and no problems in the last 6000 miles.
I believe the dealer she bought it from did not prep it right.
