Twin Cam Motors Twin Cam 1998 thru 2017
Removing exhaust header bolts
Old Sep 27, 2020 | 02:41 AM
mikeymch's Avatar
mikeymch
Default Removing exhaust header bolts
I have a 2006 harley softail and am trying to decide what to do about my new exhaust. Should I replace myself and how likely am I to break a headbolt?
Old Sep 27, 2020 | 04:03 AM
vonh12's Avatar
vonh12
It's not normally an issue. Never broke one here.
Old Sep 27, 2020 | 07:40 AM
MyFavRk's Avatar
MyFavRk
If and when you decide to replace your exhaust , start spraying some penetration oil on your bolts a couple days in advance , couple times a day and before you remove them . Then follow the proper procedure for torquing the headers to avoid any " Oh Cr__ " moments .
Old Sep 27, 2020 | 06:06 PM
mikeymch's Avatar
mikeymch
Default Exhaust header bolts
So after using penetrating fluid for a couple days should I run the engine to heat up bolts just before trying to remove nuts?
Old Sep 27, 2020 | 06:14 PM
Iceman24's Avatar
Iceman24
You're in TX...bolts shouldn't be an issue to remove. Just squirt some PO on them, let soak for a bit & give it a try. Unless they're rusted on - you should be fine.
Old Sep 27, 2020 | 07:21 PM
mikeymch's Avatar
mikeymch
Default Header bolts
Thank you for yalls replies. I do now confidently believe the exhaust will be real easy to remove. Upon further looking in and my bikes situation and the exhaust bolts actually look brand new. Last bikes bolts were in a bad way and just assumed these were too but bike was well protected these last 14years.
Old Sep 27, 2020 | 08:11 PM
MyFavRk's Avatar
MyFavRk
No need to heat them up , only thing I forgot to mention is after you soak them down , don't unscrew the nut in one turn , keep unscrewing and then turn it back in a bit , then unscrew some more , work that penetrating oil into the threads as you go .
Old Sep 28, 2020 | 07:37 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Nuts, not bolts.
Old Oct 2, 2020 | 11:35 AM
mikeymch's Avatar
mikeymch
Should I use the stock replacement exhaust header gasket or use the vance hines aftermarket exhaust gasket
Old Oct 2, 2020 | 12:30 PM
djl's Avatar
djl
Use the HD SS mesh header gaskets (PN 17048-09).
