Twin Cam Motors Twin Cam 1998 thru 2017
Magneti Marelli EFI automatic choke problem
Old Feb 9, 2022 | 03:33 AM
Brano's Avatar
Brano
Stage II
Default Magneti Marelli EFI automatic choke problem
Electra glide UC 2001 with magneti marelli
Can you help?
The choke will not turn off automatically when started. Still at about 2000 rpm when it's warm.
everything looks fine. engine running normal.
what should i check pls.? Do you have a similar experience?
Old Feb 9, 2022 | 03:49 AM
Jackie Paper's Avatar
Jackie Paper
There are some very good YouTube videos on step by step adjusting all the systems of this completely. All you need is a volt/ohm meter.
Just do a search of it on YouTube and check choke as a fine tune to the search but it would be best to watch some of the complete system ones. It's very simple with actually more user control then modern FI TCs.
PS
Jump over to the welcome area and say hello.
Welcome from North Beach, FL., USA!
Just in case you have not done both of these two important items!
Be sure to add an Avatar of your favorite shot in the USER set up for the small picture others will see in the top left corner of your post with your USER name.
And most importantly a Signature Line in your USER set up for your bike model, year, and all the letters that Harley recognizes it with that others see at the bottom.
This enables others to know your exact model if you ever ask a question or another member interested in it may ask you a question about it.
​​Your all set.... Enjoy the ride! ______________
Old Feb 9, 2022 | 06:19 AM
Brano's Avatar
Brano
Stage II
well thank you.
Budman88
Jan 1, 2020 06:37 PM
rkinggal
Apr 12, 2015 11:42 AM
GLIDE_RIDER
Aug 27, 2012 12:42 AM
GLIDE_RIDER
Aug 26, 2012 09:05 PM
TwoDinners
May 24, 2010 12:46 AM
