Only weird thing is lets say a throttle pull from 1800rpm to 5000rpm type thing itll count 1 knock so its trying to find it in there hahshss
You may want to change your plugs to stock, some aftermarket have caused false knock events
Ride the bike and log data (make sure you log in .csv format), I would do one log riding normal and one where you try to make it happen. Get a program where you can graph the logs, Mega log Viewer or Win Pep 8 are a couple. in one graph look at your knock events and in another look at TPS, RPM and MAP find out where your knock events are happening in which cylinder, then look at what's happening just before the knock event occurs and the find the same spots in your tuning tables, either add some fuel via the VE tables if that looks low or remove a couple degrees of timing,
I will definetly try that, I do have Win pep 8 and Ive graphed the data logs already but Im not the greatest on reading those type of things and figuring out the issue haha I will change the plugs out for Harley plugs, I did also notice the pv4 has auto tune features available but was wondering if the bike needed O2 sensors to use it, or are some parts of the auto functioning still ie. if the auto tune is on and the bike counts a knock would it pull timing by itself?
I think you are better off looking at the data and deciding for yourself
how old are the plug wires. replacing mine cured those events on the PV.
as far as I know theyre original plug wires, you were having the same knock count issue and it ended up being the wires? Thats something I havent even thought of actually
yes..just like yours i never heard it ping. they were the original wires.
