VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Here she is
Old Aug 3, 2007 | 01:11 PM
eazy's Avatar
eazy
Default RE: Here she is
ORIGINAL: back again
Is that the platinum silver that jet hot has?
Here's a picture of two different sets of my headpipes, one with the Sterling Silver Jet-Hot and one without---
ORIGINAL: VRodRider
How do you like that platinum suspension? I was looking into it as a possible winter project while I have the rear end taken apart to install the 5 gallon tank.
I like the Platinum a lot. The only difficulty was running the lower air lines. I used 5/16" steel brake line bent with a tubing bender to support/protect the DOT air line underneath the rear swingarm. A lot of work but the ability to dampen the rebound of the rear suspension is worth it. There is also a hard stop at ten inches so even if the rear was to drop because of lack of air pressure I would drag the rear tire on the rear fender support.
Old Aug 3, 2007 | 01:13 PM
CSI's Avatar
CSI
Very nice !!!
Old Aug 4, 2007 | 07:01 AM
back again's Avatar
back again
Thanks Easy. Gonna send them my stuff this winter. I like the heat reduction benefit. I think the color would look good on my Train. Once again nice job on your scooter.
Old Aug 4, 2007 | 11:52 AM
eazy's Avatar
eazy
My younger Brother is looking to get into a Night Train. He has kicked around a couple of ideas and has thought about the Jet-Hotmatte black. (Then he's thought about blacking out the forks and leaving the pipes chrome. Who knows what will happen in the end)
End result is that he's been on my bike with both the stock pipes and the coated ones and says he can feel a world of difference. It's good to know that the heat reduction isevidently not just all in my head.
Old Aug 5, 2007 | 06:06 AM
icecaps's Avatar
icecaps
Reading More Posting Less
Eazy,
Nice job on the V-Rod. I tried to second you into BOTM but I guess I missed the cut-off. Hope you get nominated again. It would be nice to see a V-Rod represented in BOTM.
Old Aug 5, 2007 | 01:19 PM
eazy's Avatar
eazy
Thanks icecaps, I appreciate that you think it's good enough to mix it up with the air-cooled bikes.
Unfortunately I think most will disagree. Water and Harley just doesn't seem to mix well for a lot of people.
Old Aug 5, 2007 | 10:29 PM
icecaps's Avatar
icecaps
I just appreciate someone that put a alot of work into a good job they did on their Harley. I think its realistic to know that you probably wouldn't win however I think V-Rods should be recognized.
Colormania
Jun 13, 2012 02:30 PM
soup
Mar 5, 2009 07:38 AM
Jzabel
Sep 13, 2008 05:19 PM
Bobberforever
May 30, 2008 06:39 AM
stan928
Apr 23, 2008 11:36 AM
