VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
power loss
Old Sep 4, 2020 | 06:20 AM
woodguy75's Avatar
woodguy75
Default power loss
coming home from a ride, bike lost some power, still running fine, idles fine, starts fine, plugs look good. Did a compression check, the rear cylinder is down a few psi, but do not think thats the problem. the fact that the power loss was sudden, leads me to believe something mechanical, maybe fuel pump, compression relief?, anyone have any guessses on what I should check, its is a 03 anniversary, thanks in advance.
Old Sep 6, 2020 | 04:29 AM
BBM's Avatar
BBM
Are you running a peripheral tuner or is it the factory computer?
Old Sep 6, 2020 | 07:31 AM
woodguy75's Avatar
woodguy75
It is the old screaming eagle brown box tuner, plugs read good, not wet, both are consistent burn. Runs great till you really roll into the power, doesnt stumble or sputter, just down a sizable amount of power
Old Sep 7, 2020 | 03:45 AM
BBM's Avatar
BBM
Might be that tuner.
Old Sep 7, 2020 | 07:02 AM
woodguy75's Avatar
woodguy75
Is there any way to test or run a diagnostic on these?
Old Sep 8, 2020 | 02:24 AM
BBM's Avatar
BBM
Probably, but I do not know for sure. Remove it and do a short test run.
Sdunn44
Jun 12, 2016 05:28 PM
solidaxle
Dec 11, 2013 07:35 AM
Blacklightnin
Nov 14, 2012 06:09 AM
snooper0069
Feb 13, 2011 05:27 PM
caorig
Oct 7, 2008 07:22 PM
