VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
shifter peg is a bit high
Old Apr 4, 2008 | 04:30 PM
STEG's Avatar
STEG
Default shifter peg is a bit high
got my new DX yesterday and the shifter peg seems to be standing a bit upright compared to my old bike, is there an easy fix for this or way to adsust it?
Old Apr 4, 2008 | 05:21 PM
eazy's Avatar
eazy
Default RE: shifter peg is a bit high
On my '06 the shifter rod is threaded, you need to remove one of the heim joints at the shifter pedal or transmision lever and turn the joint/rod clockwise to shorten the rod and lower the pedal height or counter-clockwise to lengthen it and then reinstall the bolt through the heim joint. If you apply locktite to the bolt do so cautiously as you do not want to get the locktite into the joint---it will seize and make shifting a real PITA.
Old Apr 5, 2008 | 07:01 PM
rjrivero's Avatar
rjrivero
As Eazy says, you can adjust the length of the rod. If you need to, you can take the shifter off the shaft by the tranny and rotate it for more room.
Cobra6
Dec 29, 2017 06:22 AM
Tek74
Feb 13, 2011 12:23 PM
VINNIE JAMES
Jun 1, 2010 04:54 AM
jm1211
Feb 2, 2009 10:45 AM
russl179
May 5, 2006 11:43 AM
