VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
V-Rod Exhaust
Old Aug 17, 2008 | 05:56 PM
mullens's Avatar
mullens
4th Gear
Default V-Rod Exhaust
I'm a new V-rod owner, and the first thing I have to do is make it sound like a Harley. I was thinking of getting the V&H doubleshot slip-ons, #18021. My question is will I have to tweak the fuel injection if I just put those pipes on (SERT, PCIII, etc.)? That's the only mod I was going to do.
Thanks
Old Aug 17, 2008 | 06:32 PM
rjrivero's Avatar
rjrivero
The 60 degree Liquid Cooled, OHV motor will never sound like a 45 degree air cooled, pushrod motor, no matter what you do to it.
After market exhausts do a nice job of bringing out a great sound, and yes, when you change your pipes, you'll need to do something to address the fuel delivery to match the flow.
For just pipes, any Pulse Width modulator will to a fine job. But for the Closed loop system on the 08's you're probably going to want to go with a PCIII with 02 eliminators, or the Mater Tune from The Turbo Shop. I wouldn't bother with the New SEPST from HD. It's not made by the same people who made the SERT, and it's got some growing pains.
Old Aug 17, 2008 | 07:04 PM
mullens's Avatar
mullens
4th Gear
Thanks..I may just stay stock. I didn't want to fool with the FI. I'm coming from a Heritage with Rush slip-ons so I'm a bit spoiled with sound!
Old Aug 18, 2008 | 08:43 PM
SilverV's Avatar
SilverV
Now it's time to get spoiled with performance! Sound shmound.
Old Aug 18, 2008 | 10:51 PM
TooTallVRod's Avatar
TooTallVRod
http://www.vrodracing.com/Informatio...austReview.htm
This site can help you out with some of your exhaust questions.
I found it helpful in my decision.
Old Aug 19, 2008 | 09:43 PM
berryp1224's Avatar
berryp1224
1st Gear
Check out the forums at 1130cc.com. This site is dedicated to the VROD and they have an extensive exhaust thread with sounds.
I just changed my exhaust on my 08 DX to the Vance and Hines Black Widows with the PCIII fuel controller (And K&N Air Filter.)
I like the new sound - Nice deep base sound...Sound files are located on 1130cc if you want to listen.
Old Aug 20, 2008 | 12:05 PM
Hal64hd's Avatar
Hal64hd
Keep in mind that the link is a couple of years old
and alot of different exhaust have been out since that link
Old Aug 20, 2008 | 12:41 PM
mullens's Avatar
mullens
4th Gear
Does the PCIII use the stock O2 sensors? How difficult was the install? I know they make an EX version now.
Old Aug 21, 2008 | 06:20 AM
rjrivero's Avatar
rjrivero
No it does not. It has o2 eliminators. To continue to use the closed loop functin, you'll need a SEPST or Master Tune from The Turbo Shop.
The EX, I believe was made because of crazy laws in Kalifonia
Old Aug 21, 2008 | 03:02 PM
mullens's Avatar
mullens
4th Gear
OK, I heard that the EX uses the stock sensors, but I wasn't sure.
