Ducati's new Vrod clone
I have 2 ducatis currently, and while it is mandatory that valve checks are done regularly every 6k or so. They are quite reliable.
I do like the old school no maintenance push rod. But there is no question that the mandatory cam activated closure of the valves on ducati's desmodromic valve is a superior design.
It does require maintenance to ensure proper gaps, but otherwise, very reliable. My 99 900ss has a big bore kit(944cc and 12.5/1 compression), it has 20k of pretty hard (read 50% track) miles on it and it runs like a top. I have not had to adjust the valves in 12k miles and most people don't have to adjust their valves to once they are settled. Otherwise, the maintenance is basically what a HD requires. Except less of a pita to change the oil (x1 vs x3).
That is not to say that some ducati's of the past are not problematic. Usually electrical problems. But then again, AMF didn't do so hot for the HD name either.
Ironically, they use magnetti marelli electronics - state of the art these days, not so hot in the past. But remember, HD has also used their stuff from time to time - and people have bitched about that too.
BTW, I also have a yamaha yz450. I ride what I ride, because it fits what I like and what I want to do.
Just like my HD
Here is a little custom shop some of you may like.
These are Ducati custom choppers. From old skewl, to pro street, to hoodlum - pick it.
Just a couple of friends that I have done some track time with over the years.
have a look,
http://www.13choppers.com/index.html
Personally, I really like them, and Mat and Kris, the builders rail on their pro-street version and sportbikes both. They get up, and they most definitely, get down. The bikes, and the riders.
have a look and comment.
http://www.starmotorcycles.com/star/...e/23/home.aspx
You don't operate a Ducati L-Twin at lo, near idle revs, they are very lumpy until about 3-4,000 RPM.
