VRSC Models V-Rod, Street Rod, Night Rod and Night Rod Special
Leaking Brake Fluid
Old Jul 11, 2014 | 11:21 PM
highhopes420's Avatar
highhopes420
3rd Gear
Default Leaking Brake Fluid
Has anybody had any luck getting the reservoirs to stop seeping fluid. I have a 2008 VRSCAW and replaced the covers because the paint had flaked, and replaced the rubber seals and they are still leaking. Its about to the the point that im going to have to replace or powder coat the master cylinder housing's on both sides.
Old Jul 13, 2014 | 04:23 AM
Hal64hd's Avatar
Hal64hd
the major cause of leakage like you describe is due to either overfilling the master cylinder or over tightening the reservoir caps
Old Jul 13, 2014 | 11:39 PM
highhopes420
3rd Gear
I checked the fluid level and they seem to be correct or pretty close. Do I need to replace the rubber seals and properly torque the screws or can I get by with just properly tourquing the screws?
Old Jul 14, 2014 | 06:01 PM
T-Rod45's Avatar
T-Rod45
As previously stated, over tightening will cause leaking. But I've found that they leak anyway over time, so I just replace the seals every year or so...
JimGnitecki
Sep 30, 2014 03:21 PM
Joanrava
Jun 11, 2011 04:47 PM
dmayer
Nov 10, 2010 11:11 AM
ron1019
Nov 22, 2007 05:27 PM
robjohnston
Dec 12, 2006 07:37 AM
