Auxililary light alignment
Old Aug 19, 2007 | 12:20 PM
eplsam's Avatar
eplsam
Stage II
Default Auxililary light alignment
Auxillary light adjustment has me baffled.Hertiage classic2005 with aux lights and turn signals.
way out of whack aligment. Is there a special tool to tighten the nut inside without cutting elec wire?
If i dissasemble the light it defeats the purpose to adjust while lit. Looks like the only thing that fits is a
split socket of some type.
Old Aug 19, 2007 | 12:28 PM
1CrazyTrain's Avatar
1CrazyTrain
Default RE: Auxililary light alignment
Welcome from Mission, Texas.
Old Aug 19, 2007 | 12:42 PM
WGRIDER's Avatar
WGRIDER
Welcome from Richmond,VA
Old Aug 19, 2007 | 01:02 PM
Blackbird's Avatar
Blackbird
Welcome aboard from Omaha, Nebraska.
Old Aug 19, 2007 | 02:16 PM
HDWG's Avatar
HDWG
Big Kahuna HDF Member
Welcome from INDY
Old Aug 19, 2007 | 02:17 PM
KeithB's Avatar
KeithB
Welcome from New York
Old Aug 19, 2007 | 05:17 PM
txgeezer's Avatar
txgeezer
Yep - find your freindly Snap On man and buy the special deep well socket with a slot in it or as some have suggested, buy a cheap one cut your own slot.
If you have passing lights, you can't live without it. Of course like everything else, once you have it, your lights will never need adjustment again or tightening again but you can help others out!
Old Aug 19, 2007 | 06:08 PM
UltraDuke's Avatar
UltraDuke
Welcome to the forums from Jacksonville, Florida![/b]
Old Aug 19, 2007 | 06:45 PM
eplsam's Avatar
eplsam
Stage II
Thanks txgeezer. time to fire up the cutoff wheels and make some sparks.
Old Aug 19, 2007 | 06:53 PM
Towpro's Avatar
Towpro
Welcome to the HDF from Northern Va.....Ride safe.
