Quick connect fuel line softtail models 2008
the female has two orings
And the male has one oring...
The female quick connector at the fuel tank has the second oring does that seat below the ball bearings in the groove, and what size is it, I'm sick of this ,,or other solutions.
That is the female side of the quick connector the oring in it currently is maybe a little small bit im about to try connect . What size is needed. Thanks in advance.
If you will take your problem over to our Tech forums you will likely find the answers you are after.
This forum is only for welcoming our new members.
PS. This is welcome area.
Do an advance search here . A few key words will get you an answer here.
Do that or repost your question under your bike or tech section using the menu...
Here or here probably is best ..
https://www.hdforums.com/forum/softail-models-7/
https://www.hdforums.com/forum/gener...-tech-tips-59/
This may be answer? Search quick connect
https://www.hdforums.com/forum/gener...ed-o-ring.html
I tell a lot of new comers to the forum to get: Factory Service manual and the Parts manual. Take to an office supply store and have them put a spiral binder in place of the glued binder. That will let the manuals lay flat on your bench. Get a three ring binder and record all your maintenance, repairs, accessories, etc. This will be a great reminder of what was done when. And great material to pass along to the new owner should you sell and upgrade. Also know how large your fuel tank is, a rough idea of your range per tank, and record your fuel usage. I have an app called Simply Auto that I record all my fuel used. I use the odometer and use the fuel gage as reference only. I reset the odometer to zero on fill ups, and I know I can safely get 200 miles on a tank on around town riding, and upwards of 230+ on trips.
