HELL leak
Old Nov 2, 2007 | 12:19 PM
MVMC_Maverick's Avatar
MVMC_Maverick
Stage I
Default HELL leak
I have a 2001 XL-1200 with a leak. The substance is a white'ish oily/slick substance that has NO ODOR! It appears to be coming from behind the oil tank and drips down onto the swing arm. It only leaks when ridden never just sitting. This started after I replaced my rear rocker box gaskets (something I have done before). I do not believe it is oil from the engine as the color does NOT match and is odorless, not to mension I am not showing ANY loss of oil level on the dip stick. I do not believe it is from the primary as the color does NOT match that either and the level has not changed. It is not anything I have been able to locate as of yet.
P.S. Water is not part of the equation.
Old Nov 2, 2007 | 01:44 PM
EZ2Rider's Avatar
EZ2Rider
Default RE: HELL leak
Maybe the wife is gettin' even for you using the oven to heat your bearings?
Just a thought!
EZ
Old Nov 2, 2007 | 07:51 PM
wallyn's Avatar
wallyn
Not sure where the battery is on a sportster nut on my old Kawi Standard there used to be a white dischargenear the battery vent line. Maybe way off base but you never know.
Old Nov 2, 2007 | 07:57 PM
Blackbird's Avatar
Blackbird
[sm=usa.gif]
Hello MVMC_Maverick.
Welcome aboard from Omaha, Nebraska.
Old Nov 2, 2007 | 08:18 PM
raftgyde's Avatar
raftgyde
Shoot! That was gonna be my guess.
8^)
Old Nov 3, 2007 | 12:17 AM
Blade68's Avatar
Blade68
Welcome from Okinawa Japan,
Blade...
Old Nov 3, 2007 | 01:52 AM
1CrazyTrain's Avatar
1CrazyTrain
Default HELL leak
Welcome from Rio Grande Valley Mission, Texas. [sm=badbadbad.gif]
Old Nov 3, 2007 | 10:15 AM
Jrsess's Avatar
Jrsess
Welcome from Wesley Chapel Fl., Ask on the tech forum.
Old Nov 3, 2007 | 10:44 AM
Peyts's Avatar
Peyts
Good to have ya amongst the rest of us! Have fun! [sm=crossbonesgif.gif]
And welcome from CALGARY, ALBERTA, CANADA!
Old Nov 4, 2007 | 04:22 PM
Jorgy1347's Avatar
Jorgy1347
Welcome to the Forum, from Ontario Canada
