Idle air control (iac)
Old Aug 30, 2009 | 02:01 PM
DARRYL L PLANCK's Avatar
DARRYL L PLANCK
Stage III
Default Idle air control (iac)
The idle air control valve open and closes contastly with the key switch off i have to pull out fuse for the electronic control module (ecm ) any suggestions .
Old Aug 30, 2009 | 03:18 PM
hpfatboy's Avatar
hpfatboy
Your posting YOUR QUESTION in the wrong section, this section is to Welcome NOOBY'S ONLY!!!
Old Aug 30, 2009 | 07:19 PM
pewterdenimbob's Avatar
pewterdenimbob
2nd Gear
I can't say i'm a harley tech but I do have some experience with cars and from what i've seen the fuel injection setup is somewhat similar. So, first thing, any "service engine" light on? (It's usually in the speedo and is the shape of an engine)
Side note:
The IAC is modulated by the ecm and of course if you kill power to the ecm it will quit doing whatever it's doing. The ecm should have constant power (voltage even with the key off) but with the key off, it should have no reason to modulate the iac. You need to see what the ecm is seeing, to do this you need a scan tool. You may end up having to get it to a shop that has these tools.
Old Aug 30, 2009 | 07:31 PM
oct1949's Avatar
oct1949
What he said..sounds good to me.
Old Aug 31, 2009 | 06:55 AM
tjvrodrick's Avatar
tjvrodrick
Welcome to the forum
Old Aug 31, 2009 | 07:13 AM
Wassup8687's Avatar
Wassup8687
Welcome aboard from New York.
Old Aug 31, 2009 | 09:55 PM
sarge40's Avatar
sarge40
Welcome from VA.
urleycay
Feb 7, 2019 06:59 AM
Mundman
Sep 30, 2018 01:45 PM
Capt. Ron
Jul 25, 2013 05:34 PM
Mike101259
Mar 16, 2013 07:08 PM
Bushy
Sep 22, 2010 08:59 PM
