Electrical Issues on 2008 Softail
Old Mar 10, 2010 | 09:26 PM
arealenigma's Avatar
arealenigma
Stage IV
Default Electrical Issues on 2008 Softail
Hey Guys…I’m new to the forum as official member…been a lurker for about a year reading the threads and getting advice…I promise to formally introduce myself later but at the moment I have an issue that has me sleepless and in desperate need of a point in the right direction…
While upgrading my signals to LED’s on my 2008 Rocker C this winter I errantly powered up the bike with some loose wires in the front switches…the turn signal wires created a short and blew the light fuse…I replaced the fuse and addressed the loose wires…turned back on…now nothing in the right switch works…the odometer/clock doesn’t come on...the signals light but do not flash…the brake light does not work…ignition switch is dead…this is all with the upgraded LED’s removed and the rear light harness unplugged(front HD signals only)...everything on the left side works fine(with the exception of the turn signals)...headlamp high/low beam...horn...
I’ve done the simple checks…all fuses…thrice…I replaced both relays…I’ve not gone through the harnesses with a continuity checker or digital multi-meter…I’ve ordered the Harley Electronics Diagnostic Manual…it should be here in a day or two…I already have the Service Manual with the circuit schematics…
I’m hoping that someone may have a simple first check for the obvious…The bike does have a security system and I am wondering if perhaps it is tripped on…my theory is that the short from the signal wire traveled back through the right side 6 pin harness…it goes to the system relay, TSSM, and ECM…I am fearful that the ECM has taken the hit…I can’t believe that it wouldn’t be better protected though…
CALLING ALL ELECTRONIC GURU’S!!!! TIA
Arealenigma~
Old Mar 10, 2010 | 09:31 PM
tjvrodrick's Avatar
tjvrodrick
Welcome to the forum. Have fun Here, Ride Safe
Ask the same question in the Softail Tech area, and you will get more answers
Old Mar 10, 2010 | 09:44 PM
wcsj55@yahoo.com's Avatar
wcsj55@yahoo.com
Welcome from northern Illinois !!!
Old Mar 10, 2010 | 09:45 PM
krjoseph's Avatar
krjoseph
Yes, the tech forums are full of helpful folks. I'm sure you can find some answers. Welcome from Music City.
Old Mar 11, 2010 | 02:33 AM
hpfatboy's Avatar
hpfatboy
Thumbs up
Welcome from Vancouver B.C. CANADA
Old Mar 11, 2010 | 04:59 AM
CB5150's Avatar
CB5150
Welcome and good luck!
Old Mar 11, 2010 | 06:08 AM
BigCedar's Avatar
BigCedar
Welcome aboard. I also had an electrical problem and the fine folks here on HDF saved me a couple hundred dollars with their advice. The Tech folks will point you in the right direction. Good luck...
Old Mar 11, 2010 | 06:21 AM
hojones's Avatar
hojones
Welcome to the forum from Virginia.
Old Mar 11, 2010 | 06:22 AM
Wassup8687's Avatar
Wassup8687
Welcome aboard from New York.
Old Mar 11, 2010 | 07:28 AM
Wallaby's Avatar
Wallaby
Post up your ? in the Electrical / Tech Forum.
Welcome aboard the Forum!
