Welcome Area OnlyNew Member Welcome Area Only. Be sure to pop in here and introduce yourself & let us know what Harley Davidson you own. Save your bike related questions for the proper area.
Hi everyone, my name is Roy and I ride a 95 Fat Boy 1340cc 80ci evo motor. I recently had a bad experience of riding my bike and the oil was leaking out of the drain line. Unaware of the problem I rode it empty and did damage to the upper end. I am currently rebuilding the motor and have some questions. The bike was bought used and it was mostly stock except the cam say's seh-11. From what I can tell this is a screaming eagle cam. I can not be sure the cam is any good so I want to replace it. But first I guess I should tell you what I am planning. I am planning on buying stock cylinders that were punched out .010 and supplied with wesco pistons and rings for a compression ratio of 10.0:1. I am planning on buying scream eagle heads. What is a good cam to purchase? Apparently the ev-27, ev-51 do not fit this bike. According to the eagle heads I can go to a .520 lift and like to stay around .495 lift. Any buddy have a good suggestion on a good cam to buy?
