Electrical issue
Old Oct 17, 2013 | 10:41 AM
aGuyFromDaytona's Avatar
aGuyFromDaytona
6th Gear
Default Electrical issue
2008 FLHTCU 42,000 miles.
Riding home & check engine light comes on, then the battery light. A little research later found reference to voltage regulator & stator. Cannot find where the stator is on the motorcycle. Am I on the right track?
Replaced to battery last year. No issues with the battery, just didn't want to be stranded with a 4+ year old battery.
Old Oct 17, 2013 | 11:02 AM
justintyme73's Avatar
justintyme73
Welcome to the forum, you will get more responses to your question if you post it outside the welcome area! You should pick up a service manual to diagnose electrical problems, the stator is inside the primary.
Old Oct 17, 2013 | 11:29 AM
DK Custom Products's Avatar
DK Custom Products
Sponsor
Welcome to the forum from Northwest Mississippi!!!
__________________
www.DKCustom.com
662-252-8828 Voice
662-420-4891 Text & Voice
Support@DKCustomProducts.com
Old Oct 17, 2013 | 01:49 PM
wyndnface's Avatar
wyndnface
Welcome from California
Old Oct 17, 2013 | 07:51 PM
the wild hog's Avatar
the wild hog
Welcome!
Old Oct 18, 2013 | 09:09 AM
cayers's Avatar
cayers
Welcome from New Mexico! The stator is inside the primary on the left side of the bike, good luck!
Old Oct 18, 2013 | 09:51 PM
zeus33's Avatar
zeus33
Big Kahuna HDF Member
Welcome from Sunny Alberta!
Old Oct 19, 2013 | 07:51 AM
nhrider1's Avatar
nhrider1
You probably won't get much technical help in the new member area...as you probably have seen.
Yes you are on the right track. If you have a charging fault it's probably going to be either the voltage regulator, or Stator. Assuming no wireing faults.
The stator is inside the primary cover (left side of engine). There are several tests you can run to diagnose the issue before you tear into it. Look in the Do It Yourself forum under Electrical and Lighting for tests and specifics.
Always start by checking the battery connections and grounds. Loose connections cause many charging issues.
Old Oct 21, 2013 | 09:45 AM
Longhair4life's Avatar
Longhair4life
Welcome
tsmithopt
Welcome Area Only
23
Apr 17, 2019 07:23 PM
smallsoldier
Oct 30, 2013 11:11 PM
1911NT
Aug 6, 2012 06:30 PM
johnfitz50
Welcome Area Only
Nov 11, 2010 10:06 AM
helstone
Sep 4, 2007 04:55 AM
