super glide front wheel
Old May 9, 2015 | 11:19 AM
brnmcadams's Avatar
brnmcadams
Default super glide front wheel
I'm looking for a front wheel for my 96 super glide .my hub is 4 7/8 wide .I got a wheel with the bike but the hub on it is 5 1/2 wide I'm not sure what it fits but doesn't fit mine
Old May 9, 2015 | 01:00 PM
multihdrdr's Avatar
multihdrdr
How bout a photo of that "other" wheel?
Your should be looking for a 99-earlier (earlier to a point) Dyna, Sportster, FXR which is equipped with Tapered Roller Bearings (something from a Narrowglide front end) for a direct fit to your 96 FXD
Old May 10, 2015 | 11:17 AM
brnmcadams's Avatar
brnmcadams
Old May 10, 2015 | 11:19 AM
brnmcadams's Avatar
brnmcadams
Old May 10, 2015 | 11:20 AM
brnmcadams's Avatar
brnmcadams
This is the wheel I have that don't fit
Old May 10, 2015 | 12:18 PM
multihdrdr's Avatar
multihdrdr
Yeah...No Worky
Did you install those bearings and Brand New Tire?
That looks to be a 2006-07 Dyna front wheel
Here's the "Show your Work" part:
- 2000/later because of Sealed Bearings (and OD of a sealed bearing)
- "Midglide" Hub (your measurements plus visual references)
- 3/4"ID x 21mm replacement bearings (KML brand - not OEM. 1" IDx 21mm of different brand (INA?) would have been STD )
- 21mm wide bearing, but Not Protruding from Hub. So hub was made for 21mm wide bearing, not the thinner 15mm wide bearing with 25mm ID (08-Later)
Did I miss anything
Old May 10, 2015 | 12:56 PM
brnmcadams's Avatar
brnmcadams
Yes I had new bearings installed and a new tire before I found out it don't fit
Old May 10, 2015 | 01:06 PM
multihdrdr's Avatar
multihdrdr
That's how we learn...betcha you won't do that again without looking, measuring, researching...even then, we all get bit sometimes
You know what to look for now...99-earlier "Narrowglide", not even a 2000-later "Narrowglide" wheel
mysturgis
Sep 6, 2014 08:53 AM
zyban
Nov 28, 2012 05:21 PM
Jaystn62
Jan 29, 2012 02:16 PM
FXD101
Jun 15, 2010 09:44 PM
bonechief
Nov 9, 2009 10:38 AM
