Help!!
Old Oct 21, 2016 | 09:00 AM
Paul Lindsey's Avatar
Paul Lindsey
1st Gear
Default Help!!
Ive searched and i cannot find anything about this on my yr bike..
I have a 2007 Harley road glide..
Does the rear tire have to come off in order to change out the brake pads?
Some people i ask say yes and some say no...
Please ..who knows for sure?
Thanks
Old Oct 21, 2016 | 09:23 AM
Tired's Avatar
Tired
Tire can definitely stay on the wheel. No need to dismount it.
Old Oct 21, 2016 | 09:26 AM
Paul Lindsey
1st Gear
So ill be able to get caliper apart to replace pads without removing the rear tire?
Old Oct 21, 2016 | 03:53 PM
Hammerhead Pat's Avatar
Hammerhead Pat
Wheel can stay on. You just have to manipulate the caliper to get it off the rotor. If you have a lift and can get the rear wheel off the ground it will give you a bit more room...
Old Oct 21, 2016 | 04:06 PM
Paul Lindsey
1st Gear
Great..i do have a lift.....i do have another question..what type pad is best for my bike..i see organics...ceramics...semi metallic ..kevlar carbon..and some have grooves in the pad some dont...im very good mechanically with cars...this is my 1st harley though so please bear with me..thanks...
Old Oct 22, 2016 | 06:57 AM
Hammerhead Pat
That's gonna be as subjective as which oil to use, LOL!! I've always used the HD pads in the past but I am changing pads today and am using some that another forum member suggested. I'll hold off on my opinion of these until I get some mileage on them( these pads were ridiculously inexpensive so we'll see). I would suggest ordering your pads from Boardtracker HD if you choose to go that route, you'll save about $40 over going to the dealership for them....
Old Oct 22, 2016 | 10:23 AM
multihdrdr's Avatar
multihdrdr
Your 2007 Road Glide has a one-piece caliper/bracket (2000-2007), unlike the two-piece on 08-later, so it can't be removed from the rotor while leaving the wheel/axle in place.
That being said, the service manual describes how to change the pads on the rear while the one-piece caliper is still in place, but it may be a bit of a "fiddle".
As per manual, you basically...
push just one pad/pistons back into the caliper (with putty knife or such)
pull pad pins
replace that one pad
install pad pins
pump pads back tight against rotor
push the other pad/pistons into the caliper
pull pad pins
replace just that last pad
install pad pins
that's supposed to keep the anti-rattle clip in place
Old Oct 22, 2016 | 12:30 PM
Hammerhead Pat
pull pad pins
install pad pins
pull pad pins
install pad pins
I stand corrected, I was not aware of this.....
Old Nov 23, 2016 | 06:12 PM
kink04fxd's Avatar
kink04fxd
It's actually that easy. Don't even need a lift.
Old Nov 23, 2016 | 06:14 PM
Uncle Larry's Avatar
Uncle Larry
Someone needs to say this ... BUY A SERVICE MANUAL. :>)
pureoper
Sep 30, 2013 07:25 AM
woodsytattooman
Aug 3, 2011 08:49 PM
albngore
Feb 14, 2011 08:44 AM
tripwire759
Jun 2, 2009 11:15 PM
Neckball
Mar 19, 2007 03:54 PM
