front 21 ridewright 02flhtcui
Would i be right in assuming that they are listed for 08-13 due to bearing size and that they will work on my 02 with 1" bearings,08-later centre spacer and trimmed outer spacer?
Wouldn't mind some opinions on the aluminum soft lip vs the steel standard style as well.
thanks
If you install your OE 2002 1" ID x 21mm wide bearings, then Yes, use the 08-later center spacer sleeve (which should be the one they used in the replacement wheel) and trim your spacers.
If you chose to use aftermarket 1"ID x 15mm wide bearings, you would still use the 08-ltr sleeve, but use the 08-ltr Dimensioned LEFT whl spacer, effectively "lengthening" slightly your OE left spacer. Re-use your Right spacer
thanks
good luck
"front 21 ridewright 02flhtcui"...So where did the "ridewright" come into this?
There's a note somewhere on their site that says they are made by Ride Wright for Drag Specialties.
I agree that the soft lip looks better,but I'm wondering how they will hold up.i guess there's too many variables to answer that.
