I recently bought a 2001 dyna superglide and i was planning to fit a 23" front wheel and 18" rear wheel, but i can't seem to find any information about this on pre-2006 dyna's?
So, my question, is it possible to fit a 23" front wheel on my dyna without changing the front suspension since i dont really like the increased rake the wide glide triple trees give.
I was actually planning to have a rim spoked to a hub i would try to buy second hand, but since its hard to find a decent place in my area that spokes wheels im trying to gather as much info as i can about it fitting or not before anything else
Alright thank you for the help, ill try measuring and see if the 23" wheel fits in my narrowglide fork, otherwise i'll probably go for a 21" or a street bob fork.
Thanks again!
Thanks again!
Specifically the TIRE fitting the space ... the 130 tire will be approx 5" wide
Also to mention ... on the Narrowglide, and depending on the Spoke wheel, your Brake Caliper may now rub the spokes
ah, yeah the caliper thing thats something i hadn't thought about. Thanks man you helped a lot.
I'll be sure to measure it out to the very smallest detail and then make my choice!
