Wheel bearings
ball bearings can take about 1/8 of load
25/52/18 abs ball bearings fatique load limit is 63kg Or so, while tapered of spherical roller bearings are over 400kg
if I just could find spherical with ABS compatible
Would change those as next bearings.
fatigue load limit explained.
https://www.skf.com/group/products/bearings-units-housings/principles/bearing-selection-process/bearing-size/size-selection-based-on-rating-life/fatigue-load-limit/index.html
tapered (angled roller) bearings can take ~1000 lbs each
Any extra like driver and wearing starts hapening
Not Even meant to last long, there are better ways
For abs sensor than one on bearings, but More $
from Spares on that way
about 800-1000 rounds per minute, typically bearings are specsed much higher rpm, If bearing fails at 18k Miles that is 300 hours at average 60mph
While I work bearings go for 5000 -7000rpm and get changed mayby once/year. Well If we divide that 300hours by 5x more rpm we would need to change
bearings twice a week every 60hrs or so...
So My opinion 300-500 hours bearing lifespan is abysmal
Well same is true almost all heavy touring bike today
Just My 2c
