Front wheel install/spacers
Old Nov 12, 2023 | 08:08 PM
Ultra Classic Sal's Avatar
Ultra Classic Sal
Exclamation Front wheel install/spacers
I have 1990 Electra Glide Ultra Classic and I took the front wheel off to get the tire replaced and I put it back on but I feel that it’s not right. I’m including a couple pics but here’s the order of spacers.
Left to right: Thick spacer, wheel, speedometer gear, three spacers then washer, lock washer and nut.
Also how tight should the axle nut be?? If I tighten it to what I think tight is then the wheel doesn’t freely spin.
Old Nov 13, 2023 | 07:32 AM
MCRD'71's Avatar
MCRD'71
Back off the torque on the wheel 'till it spins freely.
Old Nov 22, 2023 | 09:17 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Then what?
Old Nov 22, 2023 | 09:35 AM
Dan89FLSTC's Avatar
Dan89FLSTC
@Ultra Classic Sal If you are still around....
First, you need to keep in mind that unless you have owned this bike since new, someone could have installed some incorrect hardware.
The spacers appear to be in correct position in the pics, except....You say there are 3 spacers between the speedometer drive and the fork?
The speedometer drive unit itself is the only spacer on that side. Before you go any farther, you need to resolve this.
The process for installing and torquing the front axle:
Leave the axle pinch bolts snug but not tight.
Torque the axle nut to 50 ft. lb. while holding the axle with a rod through the hole in the end of the axle.
Loosen the pinch bolts to allow the right fork to find its proper position on the axle, then torque the pinch bolts to 132 INCH lbs.
If the wheel still seems hard to rotate, check the brake caliper, remove it from the fork leg, then try spinning the wheel.
If the wheel is still hard to rotate with the caliper removed, you need to disassemble, remove the bearings, clean all the grease off them and set the end play.
Old Nov 26, 2023 | 08:11 PM
Ghetto blaster's Avatar
Ghetto blaster
I agree with Dan, the washers/spacers between the speedo and the forks seem wrong, on my 88 there is a spacer on the speedo side but it is in front of the speedo drive, against the bearing, in your first pic those look like washers, and in my manual there are no washers between the speedo drive and the fork.
Old Nov 27, 2023 | 08:26 AM
davekp's Avatar
davekp
Also,
There is a gap between the spacer and fork tube on the right side. Should there be any gap?
Old Nov 27, 2023 | 08:38 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Originally Posted by davekp
Also,
Yes. The gap you are looking at is actually the fat end of the axle that is pressing against the spacer.
Here is a pic of the fat end of the axle, when it is slid in and the nut torqued, the shoulder will press against the spacer:
Old Nov 27, 2023 | 02:06 PM
Ghetto blaster
Here's a quick picture of my 88, which shouldn't be too far removed from your bike.
Old Nov 27, 2023 | 06:32 PM
davekp's Avatar
davekp
So the gap will disappear after everything is properly torqued?
Old Nov 27, 2023 | 06:42 PM
Ghetto blaster
Negative, there will be a small gap there after everything is torqued, and no gap on the speedo side.
